Old 14th March 2004, 06:07 PM   #1
VoLCoM is offline VoLCoM  Canada
Default Powering LM3886 with 12V Batteries
Is there a way to power a LM3886 Amplifier with a single...or two 12V battery by using transformers or something like that... because i'm building a subwoofer amplifier for my car... everything is soldered on the board but i need to power it up with 12 volt
i use the Minimized GainKlone Schematic with a +V and -V and GND
-Guillaume
Old 14th March 2004, 06:19 PM   #2
medum is offline medum  Denmark
medum's Avatar
You could either use 2 x 12V batteries in series with the ground in the connection between the two batteries or you could use a 12V DC to 230V AC converter and build yourself a trad. PS for the amp.
Old 15th March 2004, 01:15 AM   #3
Yes, I would reccommend the two batteries, since you don't lose current when raising voltage with the transformer.
how professional amps work i think is they have a switching (pronounced "complicated" ) power supply to create a positive and negative supply voltage.
Just so you know, the 3886 isn't going to do much damage to your ears. I would reccommend two in bridged mode, but most car subs are 4-ohm so that wouldn't work. maybe two in parallel unless your speaker is 8-ohm.
-Mike
Old 15th March 2004, 01:22 AM   #4
HDTVman is offline HDTVman  United States
You will also have the problem that the 3886 has circuitry that shuts it off when the voltage drops to 12 volts. That chip need / wants +/- 20 volts (40 volts difference) to +/- 40 volts (80 volts difference). If you want to use this in a car I would think that a amp chip designed for automotive audio would be a much better choice.
Later BZ
What ever makes the tunes flow
Old 15th March 2004, 01:24 AM   #5
alternators produce around 14 volts
Old 15th March 2004, 01:25 AM   #6
or 4 batteries in a row, +-24V
Old 15th March 2004, 01:25 AM   #7
Untill you stop at a light with the lights and heater fan on.
Old 15th March 2004, 01:30 AM   #8
i tougt there was a way to do it with diodes ... would it work?
or i'll have to add a second battery to get the 24volt? or i need batteries to get +24 and -24??
Old 15th March 2004, 01:30 AM   #9
promitheus's Avatar
To get a power supply like that you have to make a switched power supply which would cost a lot more money than the amplifier itself.
Old 15th March 2004, 01:38 AM   #10
tool49 is offline tool49  Canada
tool49's Avatar
Actually, the inverters currently sold at canadian tires (or any local store that carry that kind of stuff) might be the easiest way to go. A 400W inverter should be more than enough to power your 3886 and at 59$ it is most likely to be cheaper than the cost of adding a battery and charging circuit for it. Of course you incur more power loss than a 12V power supply circuit but it should not be THAT bad.
I also agree with promitheus about the switcher.
Sébastien
How to run an AC mic pre from batteries oaks Power Supplies 6 17th October 2009 06:02 AM
GC and batteries psu Ilianh Chip Amps 40 5th October 2009 01:30 PM
SLA batteries for UcD amp PS Paul Ebert Class D 0 16th November 2004 04:53 PM
3 pin li-ion batteries Holger Barske Parts 1 12th May 2004 07:54 PM
How long will 9V batteries last for powering opamps? PaulHilgeman Parts 4 28th February 2003 04:05 PM
Page generated in 0.11166 seconds (70.40% PHP - 29.60% MySQL) with 10 queries
