Hello,
my 4-channel Amp is driving the tweeters with an LM1876T. Since a few days when i switch the amp on there are scratchy, clicky impulses. They are not constantly there.
I disconnected the sources to check if it comes from there but it is clearly the amp.
It is not depending from the volume i set, the noise has always the same volume.
It is not the volume potentiometer which i checkt already.
What could be the problem? What should i check?
Thanks for any help!
