| Chip Amps Amplifiers based on integrated circuits |
Been lurking on the forum for a while and have seen many threads regarding gainclone PCB's. None of them seems to be complete though, the person who designed them forgot a trace here, a component there or made the tracks to narrow for high currents.
Is there someone out there who has layout files for a fully working PCB? It just needs to be a very simple layout like the one on the application note. I need to build 24 channels in one enclosure, so the PCB have to be small. They will be run from a dual supply of +/- 14 VDC driving 12 x 6ohm tweeters and 12 x 5" 4ohm woofers. For my surrond speakers... :-) |
#2 |
#3 |
Eeeeeh, Ok, I should have searched. Sorry.
Thanks though, just what I need and it was so sexy too, red and all. BAF |
#4 |
It sounds like http://www.fedde.tk ]Fedde[/URL] is the guy you need to contact. He has PCBs finished and they are ultra-compact.
PS He is in Holland.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
so this question is most likely stupid.
I understand the stereo set up of an amp you have 2 channels a left and a right. But if you want to start to build a 4.1 , 5.1 6.1 or as it seems a 7.1 how does one go to split up the channels into rear, front and center etc... channels do you need some kind of electronic splitter that splits each of the 2 incoming source channels into multiple or how does that work? plpease not toooooo technical, I was born stupid! J-P |
#6 |
usually the source (computer/dvd player etc) will have the 5.1 7.1 whatever outputs..
so its a simple matter of having enough amplifiers for each channel |
#7 |
I "think" building a DAC which support mutipule channel will work too.
#8 |
I have been looking at an old Pioneer system with surround sound
front R L, rear R L and center speaker I can hear definitely different sounds coming form different speakers (depending on the film ofcourse) but the dvd out is only 2 rca jacks for audio ( frankly I have never seen a cable leaving a dvd player that had more than 2 rca jacks for audio.... for a DAC can you give me an 'easy' schematic I would like to look at that and I understand that for each speaker I would need it's own amp so for a 6.1 i would need 7 amps, but considering the small space a gc takes i could do all of that in a relatively small enclosure seperated from the powersupply J-P |
#9 |
The 'better' HT receivers have separate preamp outputs for each channel. If you're going to roll your own amps, then you should consider a HT preamp/processor like the Outlaw Model 950.
There are no DIY solutions for a HT receiver because of licensing issues. Here is the rear panel of the 950 with all the preamp outputs (and other connectors).
If you don't measure, you don't know. |
#10 | |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.12020 seconds (78.83% PHP - 21.17% MySQL) with 11 queries |
