| Chip Amps Amplifiers based on integrated circuits |
Hi All,
I thought I'd share with you my progres on the irst Gainclone I'm building. It is based on the Peter Daniel's design and his advice, which by the way, I am very greatfull for. Thanks Again Peter !!!. I decided to make an enclosure out of 6" dia. aluminum tube (.25" wall thickness. The top will house both channels and the bottom a 400VA transformer. The Chips are LM3875. The whole thing will sit on a curly maple base. I still have to finish the PS and hope to be done this weekend Here are some pictures: Feel free to comment. Cheers, Rafal |
#2 |
Here is the top view:
#3 |
Both channels mostly done.
#4 |
Is the bridge in the bottom? Why?
#5 |
The bridge will be on top on the other side of the aluminum bars (for shielding).
#6 |
Banned
that is a cool idea.. i also have that idea but mine is a bit different. ill draw a picture and post it.. keep up the good work it looks good so far..
#7 |
I think you should relocate the switch, and make it a volume control / light / a round button switch with light instead. It looks odd when there is a rectangle switch on a rounded chassis front.
And you can improve the chassis screw hole by driling a little bigger hole on the outside of the excising hole then sink the screw into the chassis and make it parallel to the surface on the chassis. |
#8 |
Thank you all for your suggestions.
I have finally finished my amp but it has a problem. when I switch it on, it sounds fine, but after acuople of minutes, the sound gets very distorted. Can anyone suggest why that might be? Or what other info do you need to narrow down the cause? Thanks in advance for your help. Rafal |
#9 |
maybe its oscillating?
make sure there is no loose connections. -Mike |
#10 |
It could be a promlem in the wiring or bad grounding. IC amps are very sensitive to ground loops or long wires.
| Page generated in 0.32802 seconds (22.69% PHP - 77.31% MySQL) with 11 queries |
