Old 11th March 2004, 09:09 AM   #1
ebijma is offline ebijma  Netherlands
ebijma's Avatar
Default Tube rectifier for VDIGC tube psu
Hello,
I want to build a VBIGC.
And was thinking about the tube psu.
It has to be possible to use a Tube rectifier in the psu for the 6922.
The reason i want to do this is because the psu will be slow starting.
So no power up sounds.
And they (some tube forums) say the tube rectifiers sound better.
Do any of you know more about this things.
Please.....................
Old 11th March 2004, 12:52 PM   #2
Hi
Thorsten came up with an idea of using a valve rectifier here
http://ampchipdiy.com/phpBB2/viewtop...f0f00d7ad196ac
Problem is you need to delay the chip supply not the buffer,you will still get noise when the buffer starts to conduct.
I have a valve buffered chip amp along with others and we appear to agree,that atleast 20 seconds is needed to obtain zero startup noise.
Peter
Old 11th March 2004, 04:02 PM   #3
leadbelly's Avatar
The PS design in this page is closer to what you want because it is for 6922's:
http://home.c2i.net/semfielec/tubepre1.htm
For avoiding the turn-on thump, I think Joe Rasmussen's design of a small transformer left powered up continuously is most elegant, which is probably why everyone on this forum avoids building it that way
Aerodynamics are for people who can't build engines. Enzo Ferrari
RCA tube rectifier blindmouse Tubes / Valves 4 22nd July 2008 02:19 AM
Tube rectifier help Cobra2 Tubes / Valves 12 3rd March 2007 01:58 PM
6.3V Rectifier Tube Lit by 5V snoopyma Tubes / Valves 8 10th August 2005 06:15 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier ?s Tim Wyatt Tubes / Valves 16 10th March 2004 07:03 AM
Page generated in 0.08417 seconds (60.97% PHP - 39.03% MySQL) with 10 queries
