What I would do if asking a question like that is to include links to the data sheets.
That makes it easier for members to easily get the information to review to help in your quest.
http://www.ti.com/lit/ds/symlink/lme49720.pdf
http://www.njr.com/semicon/PDF/MUSES8920_E.pdf
You're welcome.
You're welcome.
Both OP amp datasheets don't show the internal circuit diagram or at least a simplified schematic as to find on page 9 under
https://www.analog.com/media/en/technical-documentation/data-sheets/ad817.pdf
I note also the absence of the residual distortion curvature as to find in post #2 under
https://www.diyaudio.com/community/...st-possible-thd-n-really-the-best-way.367692/
But this diagram isn't publish in general unfortunately.
Thus it is necessary to make own investigations (listening tests, various measurements) for individual applications (such as line-amp, RIAA amp, I/U converter, front-end for power amp like Alexander amp or active crossover networks) for finding out the sonic character.
- Chip Amps
- LME49720 vs MUSES 8920
