Hi everyone:
I bought a couple of the XY LM3886 amp boards a few months ago. I tried to connect each of these (centre tap?) amp boards to the dual secondary PSUs I built from Chipamp.com. No music. No sound. Nothing. I know the PSUs are good, because I've powered 4 Chipamp.com amp boards
with them that sound just dandy.
Can someone tell me if that is possible and if so, how easy is to make that work?
About 28V or so.
It needs + and - 28vdc to work.
That means you need +28v, -28v and a zero volt connection.
Also make sure mute circuit is connected correctly.
Mute should be pulled to -28v through a 22k resistor.
