Old 7th March 2004, 10:44 PM   #1
HDTVman is offline HDTVman  United States
Default Gain Clone amp I hate that name
I just finished my second 2 channel amp. using the National 3875 chip amp. The first one had some problems and was a retro fit for an old SS amp that was laying around. It just didn't work very well. I think the amp had some power supply problems.
The new one is a whole different story. I like this one a lot. It's scratch built, air terminial construction. It has a single +-22VDC pie type power supply. Transformer is 34VAC CT @ about 400VA, one bridge rect. from the junk box, 2 4700uf no name caps, a .47 ohm 5 watt resistor in series for each rail and then 2 9600uf no name caps. Just 10uf at the chip X 2, one for each rail.
I banged together a case from 3/4 inch plywood and masionite(sp) and some old heet sinks I had laying around. I think I have about $15 bucks in it.
It sounds very good. I am driving a pair of 4.5 inch RS speakers in TL enclosures and the computer is the source.
Oh ya, this is a non inverting amp.
Later BZ
Just wanted to add that I used the part values from the National data sheet
What ever makes the tunes flow
Old 8th March 2004, 12:12 AM   #2
planet10's Avatar
Default Re: Gain Clone amp I hate that name
Which ones? Got some pictures?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th March 2004, 11:36 PM   #3
Hi Dave
I made a mistake about the driver size. The ones I used were 4" RS 40-1040 with a spec. response of 80-20kHz. The TL was inspired by something I saw on your site, Rob Sampson's "Boomtubes". I am please with the sound of these but they do need some EQ to sound there best.
Later BZ
Old 9th March 2004, 12:02 AM   #4
planet10's Avatar
4" RS 40-1040 .... Rob Sampson's "Boomtubes"
Pictures?
dave
Old 9th March 2004, 05:30 AM   #5
Ok Dave, I don't have much luck at this but here goes.
Old 9th March 2004, 05:31 AM   #6
And here is the amp.
Later BZ
pre amp for gain clone as guitar amp engel dela pena Chip Amps 13 24th July 2009 03:46 AM
New gain clone transformer Ted205 Chip Amps 1 8th July 2008 02:24 PM
Yet another 3886 gain clone! ianpengelly Chip Amps 56 9th December 2007 02:59 PM
CD player for Gain Clone falcott Digital Source 5 26th September 2004 07:04 AM
What is a Gain Clone exactly? Lars Clausen Chip Amps 33 26th November 2003 06:33 PM
Page generated in 0.29111 seconds (26.11% PHP - 73.89% MySQL) with 11 queries
