Old 7th March 2004, 09:35 PM   #1
Send a message via AIM to geolemon
Default Orientating 2 transformers in 1 chassis
I am currently building a power supply using a single transformer -I've picked up an Avel Lindburg 625VA transformer with 25v secondaries.
I want to eventually expand this to a power supply that'll support more experimentation, and wanted to add a second, identical transformer in the same chassis, to give me the option of doubling the secondary voltage... or maybe simply powering more channels.
My question is, can I simply stack the second transformer on top of the first transformer?
I'm curious if the magnetic fields from one transformer would interfere with the other transformer, since they'd be oriented so closely... and if that would be an issue.
I haven't built a power supply before, I'm speaking more from experiences building passive crossovers, with designs orienting each inductor on a different axis to prevent the magnetic fields from affecting the other inductors.
In terms of the cosmetics and packaging that I'm shooting for, for my power supply chassis, it would be ideal if I could essentially simply stack the two transformers on top of each other.
So, I am looking to make sure this won't cause me a problem, before I build.
Old 8th March 2004, 02:46 AM   #2
Actually, did a little more searching around here, and actually found a couple threads when I used the word "stacking"...
...but they weren't exactly conclusive.
I think I'm going to try it though...
From what I read, those who were negative to the idea hadn't ever tried it... they were describing theoretical losses that were even still based on the difference between a "perfect" and "not quite perfect" transformer.
And those who actually had tried it, none of them have reported any issues at all.
If anyone does have any negative experience, I'd be greatly appreciative to hear it... but as for now, my plan is to go forward as planned, I think.
Useful Supplier of Transformers, Chokes, Chassis and other stuff poynton Tubes / Valves 0 2nd February 2007 10:48 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Audio Research D90B Chassis and Output Transformers mozfet Swap Meet 0 26th July 2003 10:09 AM
Mounting transformers, capacitors, etc. to bottom of chassis Possum Parts 20 28th September 2002 02:55 AM
Audio Research D90B Chassis and Output Transformers mozfet Swap Meet 0 19th March 2002 09:41 AM
Page generated in 0.07491 seconds (63.98% PHP - 36.02% MySQL) with 10 queries
