flaws of some powerful chipamps
Old 28th November 2016, 08:46 PM   #21
Grasso789 is offline Grasso789  Germany
They are all op-amps somehow, since they have a non-inverting and an inverting input. Yet some of them do not integrate input protection diodes. As i wrote, this lack of input protection may be good for a comparator, for which the circuit designer will tailor input protection, but not for a linear amplifier.
Old 28th November 2016, 08:48 PM   #22
Arty is offline Arty
not just somehow, they are high power opamps basicly.
V*A=VA
V*A*PowerFactor = WATT
Old 29th November 2016, 12:03 AM   #23
Fast Eddie D is offline Fast Eddie D  United States
Protection diodes are a good idea. I always include them in all my circuits.
They work like op amps of course but have application specific features. Their phase/bandwidth performance is poor for an op amp but they work great as power amplifiers.
In spite of their price, I don't think engineers use them in servo circuits. I think you could use them in some servo circuits, though.
Old 29th November 2016, 07:35 AM   #24
KSTR is offline KSTR  Germany
KSTR's Avatar
Audio chip amps are assumed to be operated closed loop, and when the loop opens during clipping it is assumed the signal is low (2...3Vpeak or so) and that there is a source resistance in the low kOhm range at both input pins. Also, common mode operation point is assumed to be very close to 0.5* total supply.
An input protection and a large input common-mode range is therefore not deemed necessary for these specialized opamps.
Old 29th November 2016, 01:56 PM   #25
Diode protection on the input ensures that the input coupling capacitor never causes the unit to latch up on power down. This is especially important when a single ended supply is used.
I use diode clamps on line level circuitry too. The diodes do nothing at all unless they're needed. They cost around 2 cents apiece if bought in bulk so the biggest cost is board space.
A couple of diodes and a resistor can provide virtually unimpeachable input circuitry protection. I don't see a downside to that.
Old 29th November 2016, 05:14 PM   #26
Here is a circuit, which likely breaks on power-up or -down, if there were no input protection diodes:
flaws of some powerful chipamps-zwischenablage02-png
In a single-chip circuit, in which i accidently shortcutted the resistor of the 2R2/470nF network, another chip broke. In both cases only the differential-input stage broke, as fuses did not.
Old 30th November 2016, 03:56 AM   #27
There's also a slow start circuit, as well as at least one error in the schematic.
A reverse biased diode from R6-R7 junction to V+ would provide positive latch up protection. If that diode forward biases on power down, then it's needed.
Old 30th November 2016, 09:37 AM   #28
The error was the missing 3u3/50V input series capacitance. A reverse diode over R8 was also cool but not mandatory in this circuit. Lastly, this 20V= generator is one for all amplifiers and so located before the fuses.
Old 1st December 2016, 07:37 AM   #29
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Ever so astonishing!
However, it is also astonishing that it is possible to get the TDA7293 to work above the claimed specs so long as one is not entirely reliant on the datasheet insistent specs.
So far as today, that is the comment that I wish to make.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 1st December 2016, 01:41 PM   #30
Thank thee, Daniel! I have to use the single rail supply, which i already have. I was worried, the nine chips could use too much idle power, heating up the cooler (9*50mA*46V=27W), but that is not the case at all; even if i cover the cooler for a while, it gets barely luke-warm. UTC state 30mA idle current but have prolly futher reduced it and shrunk the die. So it makes sense to build the circuit as small as possible, with feedback network and 100nF capacitors right at chip legs at board bottom. And use a single rail supply indeed, so the chips can be easily cooled without insulation, what also results in a low-resistance ground path, so i screwed loudspeakers ground to the cooler, too.
flaws of some powerful chipampsHide this!Advertise here!
any major flaws in this schematic joesphanlu Chip Amps 4 11th April 2016 03:49 PM
The simplest DAC power supply source design without glaring flaws? Alexium Digital Source 19 12th April 2014 07:35 PM
What chipamps to active 2-way Blueroo Chip Amps 10 7th June 2010 02:28 PM
Any flaws in my box design? icecoolwas Car Audio 4 10th August 2009 08:39 PM
Combination of chipamps mischa72 Chip Amps 15 24th October 2007 09:48 PM
