Connecting cases to ground - diyAudio
Old 6th March 2004, 11:57 PM   #1
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Default Connecting cases to ground
Hi DIY fellows,
usually, I use a 220 ohm resistor parallel with a 220 nF capacitor to connect the case with the ground of my opamp circuits. I wonder if any theory exists why these (or similar) values should be used !?
The result on two variables can be considered:
- The amount of noise that is added to the ground
- The shielding properties of the case (Faraday cage)
Any information would be appreciated!
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits...
Old 10th March 2004, 07:14 PM   #2
Anyone, p-p-p-please !?
Fedde
Old 10th March 2004, 07:16 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It seems like 220ohm is a bit high. Usually 10ohm is being used.
Old 10th March 2004, 07:44 PM   #4
breguetphile's Avatar
A step further than just a low resistance would be what alephs use. If you use a thermistor which will only be resistive when current is flowing, otherwise its close to 0 ohms. This is described in one (if not more) of the aleph service manuals.
Dawn: When men of reason go to bed. ~Ambrose Bierce
Old 10th March 2004, 09:02 PM   #5
Guys, you have no idea how thankful I am !!!
I will come back soon with a full report, but I think my amp is twice as chilling as before...
(just solved one of the biggest problems I still had)
Fedde
Old 10th March 2004, 09:23 PM   #6
uvodee's Avatar
Fedde [/B]
DIYaudio does it again.... if everything would be this easy .....
J-P
ik hou van Holland, landje aan de Zui......
Old 11th March 2004, 06:57 AM   #7
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Yup, I always do it like this. EXCEPT that you must use a NTC, not a PTC. This means that it should be about 5-10ohms when little or no current is flowing throug your ground, but it drops to a very low value when conducting any significant current. Another elegant solution would be to use a std rectifier bridge as in ZV4.
Mads K
Old 11th March 2004, 07:08 AM   #8
Theses things sre done in 110V areas. Be careful in 220V region. I don't believe one should connect reoung to chasis via any resistor!
Even the Japanese have abandoned this practice, but still seems to take place in Taiwan.
Old 11th March 2004, 09:55 AM   #9
I have a tiny bit of hum if I don't connect the case to ground (the transformers are in the same case). I now connect the case directly to ground. I'll try 10 ohm too...
Fedde
Old 11th March 2004, 03:08 PM   #10
pinkmouse's Avatar
Just a quick note, but using anything in line with the connection between chassis and the ground is bad practise, and, AFAIK, against IEE wiring regulations as being unsafe. It is also not really needed, if you think about your wiring and earth loops properly.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
connecting audio ground to Safety Earth AndrewT Power Supplies 41 30th May 2011 10:50 AM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Connecting Virtual Ground Circuits with True Ground circuits?? Minion Solid State 1 12th February 2007 01:28 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
