Neurochrome LM3886DR Build
Old 16th July 2018, 02:10 PM   #411
rsqt is offline rsqt  Germany
Is it possible by changing the coil to lower the noise (mid horn running only up to 1kHz/18-24dB/oct)?
About115dB/1W is a lot and together with a DSP it is a bit noisy.
Old 16th July 2018, 05:58 PM   #412
tomchr is offline tomchr  Canada
tomchr's Avatar
Put a shorting plug on the input of the amp. If the noise level drops to an acceptable level (preferably well below audible at the listening position), messing with the amp won't change anything. You'll have to get a quieter DSP.
Messing with the output inductor will not change the noise level of the LM3886DR. You might be able to lower the noise a bit by messing with the feedback networks around the LM3886. Ensuring stability across the entire signal swing while doing that is a challenge, however.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 16th July 2018, 09:02 PM   #413
BrianL is offline BrianL  United States
rsqt,
The output inductor is part of the RL network to help assure the amp's stability with odd loads. It is not a noise filter.
bel
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome Differential preamp build IanLenco Analog Line Level 34 29th May 2018 06:58 AM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 04:46 PM
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 22 12th November 2016 10:42 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 54 5th September 2016 05:53 AM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
