Neurochrome LM3886DR Build
Old 14th September 2017, 08:52 AM   #271
R.I.P.
Shame.
I found a link for downloadable software some while ago, but can't find it now.
Another Member was asking about device location details, but I was unable to refer him to the manufacturers' recommendations.
regards Andrew T.
Old 14th September 2017, 11:17 AM   #272
mickeymoose is offline mickeymoose  Canada
Heat Sink Peltier Cooler Heat Spreaders Site Map | Novel Concepts
Old 14th September 2017, 11:29 AM   #273
R.I.P.
Heat Sink Peltier Coolers Heat Spreader Calculator | Novel Concepts
This calculator will not work for a vertically oriented passive heatsink. Nor will it show the temperature profile over that vertical surface/interface.
regards Andrew T.
Old 9th February 2018, 02:49 PM   #274
Mixi is offline Mixi  Austria
can anyone tell me which class of amp (AB ?) the lm3886dr is? i hope this isn't a super silly question ....
Old 9th February 2018, 06:21 PM   #275
adason is offline adason  United States
adason's Avatar
AB
Old 9th February 2018, 08:01 PM   #276
HSonHSon is offline HSonHSon
This is a trick question.. depends on the voltage you give it... if you give it enough volt, it becomes class A.
Old 9th February 2018, 10:58 PM   #277
adason's Avatar
Its like magic!
No, no amount of voltage will convert class AB design into true class A.
Old 9th February 2018, 11:54 PM   #278
tomchr is offline tomchr  Canada
tomchr's Avatar
The LM3886DR is Class AB. In order to change it to Class A you would have to increase its bias current dramatically. This is not possible without redesigning the LM3886 IC.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 11th February 2018, 12:15 PM   #279
thanks!
TI list the lm3886 as a Class D amp (link),. Would it be very difficult to explain how it "turns into" a class AB in this application?
Best, Michi
Old 11th February 2018, 12:22 PM   #280
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Thankfully they get it right in the parametrics. Bare in mind it could have been made and that could have been written almost anywhere in the world
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome Differential preamp build IanLenco Analog Line Level 34 29th May 2018 06:58 AM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 04:46 PM
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 22 12th November 2016 10:42 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 54 5th September 2016 05:53 AM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
