Neurochrome LM3886DR Build
Old 3rd September 2017, 09:31 AM   #251
Mixi is offline Mixi  Austria
So i can attach the ground to the baseplate, right? It doesnt have to go to one of the outer panels as the baseplate will be connected to them anyways.
Old 3rd September 2017, 10:10 AM   #252
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Not the best, on back panel close to inlet is recommended. What enclosure are you using?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 3rd September 2017, 11:42 AM   #253
ok, i can take it to the back panel right next / above the mains inlet. thanks of the advice!
i'm using a galaxy 2u chassis with additional base plate:
Galaxy 2U
Base Plate
Old 3rd September 2017, 02:14 PM   #254
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Mixi View Post
thanks tom for the debugging suggestion. I'll try to finish the enclosure as soon as possible and if the noise is not gone by then i'll try further debugging.
my build process has slowed down a bit due to a shoulder injury but i'll eventually get there....
If you can hear it, it is probably not rf interference ;-)
Another thing to realise is that with just a few mV input your S/N ratio is relatively low giving the impression of highish noise, which will disappear with 'normal' listening levels.
Jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher
Old 3rd September 2017, 05:32 PM   #255
tomchr is offline tomchr  Canada
tomchr's Avatar
Unless the RF is demodulated by a diode junction somewhere and turned into bouncing DC. Happens all the time with GSM cell phones. The RF bursts of the GSM signal can cause the DC offset of an input stage to bounce which results in the BRRZT-BRRZT that you hear in the speaker as a result. That's one of the many reasons I put the RF filter on the input of the LM3886DR.
I recall the design review for the LMV851 EMI hardened opamp to be rather interesting. The applications team had fun trying to "break" the chip. You can see the results, including the cell phone call I mentioned above, on page 16-17 of the LMV85x data sheet.
True. You can't move electrons without causing noise. That said, with a medium-efficiency speaker (say 85-87 dB) an LM3886 amp should not generate enough noise to be bothersome at the listening position. I measure 43 uV RMS 20Hz-20kHz (unweighted) on the output of the LM3886DR.
Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 10th September 2017, 07:27 PM   #256
i finally finished the enclosure for my 3886dr project last night. to my great satisfaction the noise problem i had earlier disappeared almost entirely once the enclosure was finished and the ground was securely connected. what remains is tiny amount of white noise which is only audible if i hold my ear against the tweeter and listen very hard.
i'll post more later - for now i am very happy the way it turned out.
Old 10th September 2017, 07:35 PM   #257
Congratulations Have you ever held a shell to your ear and heard the sea?......
Old 10th September 2017, 07:38 PM   #258
uhm .... ok, i'll shut up about noise now :-)
Old 10th September 2017, 07:41 PM   #259
How about some pictures, we like pictures too
Old 10th September 2017, 09:20 PM   #260
tomchr's Avatar
Awesome! Yep. That noise you're hearing is the 40 uV RMS (unweighted) of the LM3886 along with whatever acoustical noise is in your head. It's normal.
Sounds like a plan. I'm glad the amp worked out well for you.
Yes, please. I'm curious what you ended up with.
Tom
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome Differential preamp build IanLenco Analog Line Level 30 26th November 2017 05:36 AM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 05:46 PM
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 22 12th November 2016 11:42 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 54 5th September 2016 06:53 AM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 09:15 PM
