Neurochrome LM3886DR Build
Old 23rd August 2016, 11:07 PM   #11
dreadnoughtstrength is offline dreadnoughtstrength  Australia
Originally Posted by tomchr View Post
Cool! Nice work!
Math is Pout = Vout^2/(2*Rload) with Vout in volt, peak.
or: Pout = Vout^2/Rload with Vout in volt, RMS.
Tom
That's about what I figured; close enough to 50w!
Knocked this box up in Solidworks, but the guy helping me CNC said it's not 'sexy' enough (he's a crazy German engineer haha), so we're redesigning. Still undecided if I add a preamp and some other bits and pieces in or not, I'd love matching PSU/amp boxes but running a preamp with that just complicates umbilical wiring.
Old 24th August 2016, 02:39 AM   #12
tomchr is offline tomchr  Canada
tomchr's Avatar
I'd shy away from umbilical cords. Using such cords increase the supply impedance which will degrade performance. There's no need to keep the amp and supply separate.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 24th August 2016, 03:01 AM   #13
jwicaksana is offline jwicaksana  Indonesia
Nice build!
Jonathan
Old 25th August 2016, 10:49 PM   #14
chrisb is offline chrisb
Tom
The little prototype of yours we played with last week was a tidy compact build with no detectable noise, and I think you've sold me on the Speakon connectors, and use of balanced inputs when available. I was already a convert to SMPS for lower rail voltage circuits.
like my mind, this space intentionally blank
Old 25th August 2016, 11:39 PM   #15
Bare is offline Bare  Canada
Clearly you haven't yet had an SMPS.. Fail.. taking out your amp.
Not to worry, there's good prognosis for enjoying that singular pleasure.
Old 26th August 2016, 12:59 AM   #16
tomchr's Avatar
Chris and I spent a bit last Thursday listening to my LM3886DR + SMPS-86 amp. No blown speakers here. The combo also performed well during my testing.
I've tested the SMPS-86 with my Modulus-86 as well. Same stellar performance. About a year ago, I tested my Modulus-86 on a SMPS300RE from Connex. Worked great!
While it sounds like you had a rather bad experience, I think your experience is an isolated case and should not be generalized to switch mode power supplies in general.
Tom
Old 26th August 2016, 09:13 AM   #17
R.I.P.
I have not yet built any power amplifier with an SMPS as the PSU.
I do have a lot of user experience of mains transformers and mains to DC SMPS.
I have NEVER had a mains transformer failure.
I have had dozens of mains SMPS failures.
regards Andrew T.
Old 26th August 2016, 08:21 PM   #18
tomchr's Avatar
I've had mains transformers fail. I haven't personally experienced an SMPS failure. See. This is the problem with basing design decisions on personal anecdotes. You don't get the full data set.
Considering the number of switching power supplies in service world wide, you will see some failures even if the failure rate is in the ppm. I think blanket statements like SMPS = BAD are based on emotions rather than facts.
The SMPS modules I use in my SMPS-86 are well designed and very rugged. They include protection against various fault conditions, including over-current and over-voltage. On top of that, I added surge protection and inrush current limiting.
Tom
Old 28th August 2016, 10:41 PM   #19
TioFrancotirador is offline TioFrancotirador  Poland
Hi tomchr,
While waiting for your PCB to come I am collecting the parts. I am curious of the function of 20k resistor + 47pF in parallel to another 20k resistor in feedback loop. Can you explain what is it for? Is it necessary? What is the downside of not having this RC network, leaving just this 20k resistor like in other designs.
Old 28th August 2016, 10:50 PM   #20
tomchr's Avatar
As described on page 8 in the LM3886 data sheet:
The cap across the inputs (Cc in the data sheet) prevent quasi-oscillation as the output voltage swings near the supply rails. This results in a cleaner output and slightly higher max output power. The drawback is that Cc causes some overshoot on the transient response.
Rf2 and Cf are introduced to combat this overshoot and keep the amplifier stable.
The three parts are necessary if you want good performance.
Tom
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome Differential preamp build IanLenco Analog Line Level 34 29th May 2018 06:58 AM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 04:46 PM
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 22 12th November 2016 10:42 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 54 5th September 2016 05:53 AM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
