Neurochrome LM3886DR Build
Old 11th July 2017, 03:53 PM   #171
Mixi is offline Mixi  Austria
sorry for stressing this topic once again ...
... so the "E" version (high capacity) might as well be used as the "normal" version?
Old 11th July 2017, 04:12 PM   #172
BrianL is offline BrianL  United States
That seems to be what Tom indicated.
bel
Old 11th July 2017, 06:07 PM   #173
tomchr is offline tomchr  Canada
tomchr's Avatar
The high capacity 'E' version can handle 5 A. The non-'E' version can handle 3 A. They're interchangeable in this application but the 'E' version is more expensive.
Attached figure is from Page 2 of the data sheet and explains the difference between the normal and high-capacity versions of the relay.
An easy way to find the data sheet is to type the part number into Mouser. The product page will have a data sheet link near the top of the page. Alternatively, one can type the part number into Google. That works for the relay in this case, but for other parts getting Google to come up with the data sheet hosted by the manufacturer can be a bit of a gong show. Mouser (or the manufacturer's website) is more handy for that.
Tom
File Type: png Screen Shot 2017-07-11 at 12.08.55.png (105.8 KB, 450 views)
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 11th July 2017, 09:11 PM   #174
Thanks for your (very beginner friendly) explanation!
Old 21st July 2017, 08:57 AM   #175
so after waiting for more than a month this thing just arrived ... very heavy. i hope it will do the job. finally i can make some progress on this project.
... coffee beans are just for size reference ... :-)
Old 21st July 2017, 04:36 PM   #176
tomchr's Avatar
Looking good!
Tom
Old 22nd July 2017, 08:45 PM   #177
454Casull is offline 454Casull  Canada
Where did you order the heat sink from?
Old 23rd July 2017, 08:58 AM   #178
these guys right here .... based in germany.
Fischer Elektronik
Old 23rd July 2017, 09:00 AM   #179
gkh is offline gkh  Austria
gkh's Avatar
Fischer Elektronik
One of the best suppliers
Old 1st August 2017, 05:30 PM   #180
so today I'd need some advice regarding binding posts. i see a lot of fancy ones that seem to be crazy expensive and I also found these that a very cheap but are not "designed for hifi" .... Hirschmann
are any significant differences to be expected .... other than the fact that they look different?
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome Differential preamp build IanLenco Analog Line Level 34 29th May 2018 06:58 AM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 04:46 PM
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 22 12th November 2016 10:42 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 54 5th September 2016 05:53 AM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
