Old 3rd March 2004, 09:17 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default Do I need a LPF?
Hi all,
I want to build a simple 5.1 gainclone with 2 TDA7370s... Each channel (except subwoofer) will be 7W (%10THD) and sub will be 24W. That gc will be used for a cheap DVD's analog 5.1 output.
The question is; do I need a low pass filter and/or a preamplifier for subwoofer input?
Thanks for your interest in advance..
Old 7th March 2004, 12:47 PM   #2
Well I guess in such a case you wont be needing a LPF as DVD's analogue out at subwoofer has already LPF.
Old 7th March 2004, 02:37 PM   #3
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
it does have a LPF but often it's filtered way to high...
I used a passive 100Hz LPF and that sounds way better...
Old 8th March 2004, 06:25 AM   #4
Dxvideo's Avatar
Thank you very much.... I will finish the project in this week. The main problem is volume control... I guess I will use four seperated pot..
Old 8th March 2004, 01:15 PM   #5
macboy is offline macboy  Canada
For volume control, try the National LM1036. This IC controls the volume, bass, treble, and balance of 2 channels using DC voltages to control each of those parameters. You can use three of them for 6 channels, using the same voltage to to control the volume on all of them. This chip will add a very small amount of distortion, but it doesn't seem like you are shooting for stellar sound quality to begin with.
Page generated in 0.07834 seconds (66.53% PHP - 33.47% MySQL) with 9 queries
