| Chip Amps Amplifiers based on integrated circuits |
I've been using CT transformers for all my GC type amps with zero problems. However, I was toying around with quasi grounding and such. I found that I could actually "get by" pretty well with a pair of 2W 430ohm resistors forming a voltage divider across the +/- DC input to make a "floating" ground. It works with no hum and nothing gets hot....can it be used long term like this? Are there side effects? BTW, I'm using a 4766T (stereo 30WPC).
Also, I came across a commercial subwoofer amplifier using the TDA2050. It was a (rated) 35W unit and utilized a voltage doubler recitifier on a single secondary transformer. It worked very well - I thought voltage doublers were only good for very low power amplifiers/processors?? Anyone else have experience with this? I have reasons for wanting to reduce costs... |
| Need help with voltage doubler | Lingwendil | Power Supplies | 6 | 22nd April 2009 12:15 AM |
| Voltage Doubler | jwatts | Tubes / Valves | 3 | 2nd January 2009 12:13 AM |
| one trafo->doubler+rectifier paralel? | darkfenriz | Power Supplies | 16 | 5th April 2005 01:14 AM |
| Voltage doubler | Baard | Solid State | 28 | 17th January 2005 04:46 AM |
| Page generated in 0.07170 seconds (69.51% PHP - 30.49% MySQL) with 10 queries |
