Old 1st March 2004, 11:08 PM   #1
2Bak is offline 2Bak  Denmark
Default GC 0,22R output resistor
In one of my Gainclones I use Caddocks MP915 0,22R in output with this schematics: http://home.comcast.net/~greggbaker/invertedLM3875.gif
Those Caddocks are quite expensive. In another of my Gainclones I used an inexpensive 0,2R power resistor, and I'm rebuilding this one, so maybe I should use the opportunity to switch to Caddocks while I'm at it, however I'm not sure I could hear any difference compared to the Caddocks....
My question is: Does the quality of the 0,22R resistor have any importance on the sound quality of this amp, at all..?
I am gonna use this 0,22r, and I won't leave it out as many have suggested
Jan
Old 1st March 2004, 11:17 PM   #2
leadbelly's Avatar
I do not understand why you would post this. You are in a privileged position of having a GC built one way and a GC built the other way. Don't you trust your own ears? Did I miss something?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 1st March 2004, 11:20 PM   #3
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Indeed, try listening to both configurations yourself, and I also recommend trying it without any resister in series with the output.
Brian
Old 1st March 2004, 11:25 PM   #4
Banned
the best you can do for your reputation on diyaudio.com is to post the GC sound much better with the expensive resistor, and you will never go back and use cheap resistors anymore. You even canīt understand how you ever listened to any music before with pleasure.
I personally donīt belive you or anyone human is able to hear any difference between resistors, but oops, it was a big mistake of mine to admit this here in public.
Old 2nd March 2004, 12:10 AM   #5
At the moment with my speakers and all my other gear, I cannot hear any difference. Perhaps If I tried those two configurations on some other gear I could tell a difference, who knows.
Music is what matters for me, not components. And I wonder if I was a fool spending that money on the Caddocks in the first place ;-)
Being hooked on DIY, sometimes I find myself loosing my ground control, and presuming expensier is better, instead of using my time on listening to music, that's for sure.
I trust my ears and my feelings when I listen to good music. I'm not sure I trust my ears when I have to audition audio gear.
But most importantly: I'm happy with my DIY amps and that's what counts for me, and I believe I've found in the Gainclone an amplifier I can live with for many years.
Yes Leadbelly, this posting was a waste of time.
Old 2nd March 2004, 12:20 AM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Don't use any resistor, you probably don't need it.
Old 2nd March 2004, 12:23 AM   #7
Maybe you should read this?
http://www.audioasylum.com/forums/hi...ges/15679.html
Old 2nd March 2004, 12:23 AM   #8
Banned
ok, you are on the right way, a little reflexion like that is something a lot people on this board could need...
Old 2nd March 2004, 12:31 AM   #9
Why, Peter...?
What's it used for, by the way?
/Jan
Old 2nd March 2004, 12:54 AM   #10
Having an 0.22R allows you to omit the output inductor.
Though adding the missing Zobel seems a good idea to me.
sreten.
Opamp output resistor.. jethdub Chip Amps 3 21st January 2008 04:46 PM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 03:55 PM
why a cap and resistor at output of leach? Wagener Solid State 2 13th August 2004 08:08 PM
5% output resistor xplod1236 Parts 4 31st July 2004 01:29 AM
Gainclone output resistor aeronaut Chip Amps 17 7th May 2004 10:26 PM
Page generated in 0.13379 seconds (75.31% PHP - 24.69% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
