| Chip Amps Amplifiers based on integrated circuits |
#11 |
I've seen some people experiencing problems with wrong choice of speaker wires (mostly distortions at high frequencies). Zobel didn't help at all, changing wires did.
![]() In all the amps I built (always without resistor), the resistor was not needed. |
#12 |
Do not use a 0.22R series resistor at the output by itself. This resistor is only meant to be used in conjunction with an output inductor.
1) Output inductor is used to to provide a stable load when driving highly capacitative loads, e.g. long speaker wires. 2) Series resistor (paralled with the inductor) is to damp the LC combination. Zobel network is for a totally different purpose. It's to provide a load at very high frequencies (where the speaker is no longer 8R). For highly stable amplifiers like these (if used correctly), output inductor/resistor combo is not needed. Neither is Zobel. |
#13 |
These resistor is mandarory only in case, if you can connect two channel in parallel mode. In another cases you may let it. But remember on this - if you connect two amps in parallel without this resistors, it will be deadline for both.
#14 | |
#15 |
Right
#16 |
I just wonder why the all schematics I've seen on
http://www.ampchipdiy.com/phpBB2/viewforum.php?f=2 includes this resistor...? Also the most updated one http://ampchipdiy.com/invertedLM3875_r2_1.gif But perhaps I should ask this question on the ampchipdiy.com forum itself... I guess quite a few who have build this variation of the IGC have included this resistor. At least those not so experienced DIY builders like me, who stick to the book to be on the safe side ![]() If one uses this resistor, and since it's more a part of the speaker system than the GC circuit, a good non-inductive resistor must be an advantage then, and maybe my Caddocks was not such a bad pick after all... /Jan |
| Opamp output resistor.. | jethdub | Chip Amps | 3 | 21st January 2008 03:46 PM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| why a cap and resistor at output of leach? | Wagener | Solid State | 2 | 13th August 2004 07:08 PM |
| 5% output resistor | xplod1236 | Parts | 4 | 31st July 2004 12:29 AM |
| Gainclone output resistor | aeronaut | Chip Amps | 17 | 7th May 2004 09:26 PM |
| Page generated in 0.11661 seconds (60.56% PHP - 39.44% MySQL) with 10 queries |
