| Chip Amps Amplifiers based on integrated circuits |
I want to build an amplifier with 2 TDA7294's in bridge configuration. I would like to use the following schematic http://maryus17.freeservers.com/photo4.html .Can someone take alook at it and tell me if it's better than the one found in the Tda7294's datasheet.Do you know what kind of pot is r3 and what is it for?
Thx! |
#2 |
Doesn't anybody know?
I want to build a tone control unit with Tda1524 or Tda1526 or with ne5532 . Wich is better to use with the tda7294?Pls answer me! Cheers! |
#3 |
#4 |
I have made my amp after that schematic and it works very well!
#5 |
This schematic mentioned in the official data sheet of the chip is alright but is mentioned in the schematic that it could not drive loads less than 8ohm, can anyone transform it to dreive loads like 4 OHMS?
#6 |
Telling that It can't drive 4R loads is false, IMHO.
Look at the TDA7294 datasheet, there's a curve showing the minimum load vs the supply voltage This means that you can't drive low loads with high voltage rails AT FULL POWER, because it will clip before. Driving low loads with high voltage rails much below the full power will work, but this may be nonsence You'd better use lower voltage rails, that fit your load. But to prevent the chips from clipping with a 4R loads, the rails could even have to be set to 10V or something like this. I think that this is the main problem But, why do you want a bridged amp for a low load? You'll get more power in it with 2 paralleled modules |
#7 | |
Any help will be appreciated. |
#8 |
There's a schematic for this in the TDA7294S datasheet (you can find it at ST)
That's figure 7 |
#9 |
Yes with paralleled mode you can use less sepaker impedance. But 7294 or 7294V is not the best solution. 7293 and 7294S chips have pin for parallel mode. I made this in these days, but unfortunately three chips demaged while I tested (the PCB got only + power). So now I have PCB for bridged/parallelled 7293, and I have single parallel amps because no chips enought
#10 |
can somebody refresh this pictures? I canīt see them
sign. free |
| Tda7294 | e_fortier | Chip Amps | 2 | 27th November 2008 02:33 PM |
| My TDA7294 Amp | panson_hk | Chip Amps | 1 | 27th June 2007 02:06 PM |
| Help...TDA7294 bridged can't work | yikchean | Chip Amps | 5 | 3rd December 2006 05:06 PM |
| Need help on tda7294 amp | Fossil | Chip Amps | 6 | 20th April 2005 03:53 PM |
| Problem with bridged tda7294 | CPX | Chip Amps | 9 | 31st December 2004 11:08 AM |
| Page generated in 0.10487 seconds (77.58% PHP - 22.42% MySQL) with 10 queries |
