Old 27th February 2004, 02:34 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default GC As Driver Stage For High Current Amp?
Hello, I am hoping to make a very high current but simple amp for a subwoofer. We are talking 2 and maybe 1 ohm load. Obviously that's too much current for a chip amp, but what if you used the chip amp to an output stage that had some high current power transistors? I have looked here over 100's of pages and have not seen a suitable circuit. The National data sheets show complicated arrangements and don't give me the level of current I am after. It of course would only need to be 1 channel.
Does anyone have a circ for a high current amp using a GC as the driver stage? Or if not, a circuit for just an output stage that provides high current? 10 amps? 20 amps?
Old 27th February 2004, 04:33 PM   #2
pinkmouse's Avatar
I think Circlotron did something like this with a Quad current dumping type circuit a year or so ago, might be worth a search...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th February 2004, 04:36 PM   #3
pinkmouse's Avatar
Thought so, here you go...
Al
Old 28th February 2004, 03:21 PM   #4
djk is offline djk
djk's Avatar
If you stick a couple of 1 ohm resistors in the power supply leads they can drive external outputs.
With a suitable supply, 400W at 1 ohm is possible.
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 10:43 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 07:06 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 01:17 AM
Page generated in 0.07778 seconds (70.78% PHP - 29.22% MySQL) with 10 queries
