| Chip Amps Amplifiers based on integrated circuits |
Purely theoretical at this point.
I'm wondering about the following method of obtaining a higher output. The output of most chips is limited by the rail voltage. In case of a lm3886 with e.g. +/- 30V supply you could get 30-40 watts into 8 ohms. What if you would use a tranformer after the output and double the output voltage. This means of course that in order to supply the current, the impedance the chip sees drops. This could be solved by putting multiple of these transformers in series. The advantage could be that small DC offsets would not matter. In addition maybe matching of components would not be as critical. With a bridged design you may quadruppel the power again and get up to 500W into an 8 ohm speaker. (Although at the cost of 8 chips). Has anybody done something similar considered this? Or is my idea flawed? Harry Andree |
#2 | |
Flawed? Nah! You have just invented the perpetual motion machine! Again! You can't get higher power out by using transformers (or other witchcraft). The end.
Hmm .. no .. I really haven't got anythig cool to say .. |
#3 |
I'm not trying to create power here.
If 2 chips bridged cap put out 100 W bridged at 8 ohms then 8 chips bridged parallel can put out 400 W at 2 ohms. You should be able to use a transformer to get the output to be 400 at 8 ohms. Now by putting many chips in parallel I should be able to sustain the higher current that is required for the higher voltage. Harry |
#4 |
Why not build an amplfier that is designed for these sorts of output powers, there are plenty out there, and they will be a lot cheeper than trying to find a suitable transformer (in terms of frequency response as well as power ratings), and will give a far better frequency response overall.
It just seams like trying to make a chocolate teapot when you would be far better off going for something a little better suited to the task at hand. |
#5 |
What you're asking for can be done, theoretically. But transformers are big, expensive, and have losses. Finding a 400 watt transformer to go from 2 ohms to 8 will cost you more than a 400 watt amplifier.
dave |
#6 | |
You don't need the output transformer if you parallel the chips! Just feed them all with the same input (possibly needing a buffer) and the same supply voltage, and add the outputs together. Voila, done.
#7 | |
The idea of the transformer is not so wild but difficult to implement and expensive. Some of the difficulty comes from the requirement the transformer to have a step-up ratio. Otoh you don't need a lot of primary inductance. It may be interesting to test this with a mains rated transformer with 1:2 step-up. I seem to recall someone manufacturing similarly speced step-down transformers for OTL tube amps. The response to those was mixed. |
#8 |
In most Public Address amplifiers this is just routine. In Europe PA amplifiers have a standardized voltage output of 100Vrms at full output, in the USA this is 70V. PA loudspeakers are also standardized to these voltages, so you just connect many of these speakers in parallel up to the specified max output power.
The amplifier uses an output transformer to get an isolated 100V output and the loudspeakers use an input transformer to step down to the voltage that matches the actual speaker. Because most PA amplifiers should also be able to deliver their output when running from a battery (often 24V) instead of mains, the actual supply voltage in the amplifier is very low. While running from mains the supply voltage is often around 28V and the 24V battery is connected to the supply voltage via a diode. If the mains fails, the battery acts as a secondary power supply and takes over automatically. The diode protects the battery from being (over)charged from the mains and avoids that the battery is loaded while the mains is still present. You can buy 480W amplifiers that run from 24V (supply current 30A). http://www.pacat.co.uk/PDFs/Plena/Bo..._32412.pdf.pdf Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#9 |
Does anybody know a source of
high-end transformers for this purpose? Harry Andree |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 09:05 PM |
| high DCR secondary (power transformer) | jarthel | Tubes / Valves | 2 | 16th June 2007 10:44 AM |
| Class D high frequency output transformer | Bazukaz | Class D | 1 | 21st January 2006 04:24 AM |
| Transformer for high power amp | kon_udorn | Solid State | 4 | 8th April 2004 06:07 AM |
| high power output instrument amp | fezz | Instruments and Amps | 3 | 14th September 2003 10:56 AM |
| Page generated in 0.10883 seconds (81.49% PHP - 18.51% MySQL) with 10 queries |
