| Chip Amps Amplifiers based on integrated circuits |
How do you implement a stereo volume control with only one volume dial? I could not find any schematics or explinations I could make sense of.
Thanks, Adam |
#2 |
Dual pot.But most of the time you have to add a resistor to make them equal.
ron |
#3 |
You could use a Maxim DS1802 Digital Pot. You can do a simple pushbutton (up / down) configuration that requires no special hardware.
Heres a link to their PDF about how to build one....quite easy looking. Or you can use a single gang potentiometer to drive a digital pot. The circuit tracks the analog pot and sends a digital signal to the digital pot. Thus giving you the resolution and channel acuracy of a digital pot, with the feel of a analog pot. Heres the link |
#4 |
As far as using a resistor on a dual pot, I'm assuming you mean adding a resistor to one pot to offset the difference? The only problem I see with that is that at minimum and maximum positions, they will be off by whatever the resistor is. But who spends time at min or max anyways!?
Unless you mean in parallel or something? |
#5 |
Yep, thats why i use 2 pots.I have yet to find a truly equal dual pot.
ron |
#6 |
How about a dual gang volume pot followed by a dual gang balance pot?
#7 |
Or just 2 pots which is a combo volume/balance?
I find that as i sit in various positions positions in the room i have to adjust to different levels (channel volume postions) to get a balanced sound, but i am using narrow beam (8") FR pipes.So the sweet spot is a bit smaller than multi ways. ron |
#8 |
Banned
or use a PGA2310
#9 | |
#10 |
So can you use a digital pot with an active crossover circuit, that way you have very high resolution and consistant selections?
Using the pot as the resistor in the active crossover circuit? That would be cool, becuase then one knob could control an <infinite> amount of channels to all be at the same level. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 08:20 PM |
| Installing Stereo Volume Control On Patio! | mideus | Multi-Way | 1 | 17th May 2006 05:39 AM |
| Niles in-wall stereo volume control (L-pad) | orthoefer | Swap Meet | 1 | 9th May 2006 01:39 PM |
| dc operated stereo volume control | steven344 | Chip Amps | 4 | 1st December 2005 01:40 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 12:12 PM |
| Page generated in 0.09196 seconds (79.00% PHP - 21.00% MySQL) with 10 queries |
