| Chip Amps Amplifiers based on integrated circuits |
Hi everyone,
Im a newbe around here, have been following the trend, and tried to build a Gainclone. anyways I have got to a point where I need Help! my problem: I am getting stange pops from the speaker. and have measured the terminals and they seem to read 35v on them this is a non -inverted gainclone based on these scmatics: only difference is i have left out R3 and C2 and am using 22k resitors instiad of 20k's and all earth cables go to one point (C3) earth and then out to the Power suply. I have tried putting in R4 and is now left off. any help apriciated easyrider |
#2 |
Poping? isint he the guy in the funny hat?
Make VERY sure that the caps to the power pins has the correct polarity. ron |
#3 | |
The first things to do is check your power supply. If you are using a transformer with 18 volt secondaries, you should have rails of +/- 27-28 volts DC. If you use a transformer with 24-25 secondaries, the rails should be 36-37 volts DC. If you have the correct supplies, make sure that the power is connected to the chip. I would guess if you have 35 volts on the speaker terminals, one rail is not connected. Remember to measure the output on the speaker terminals with a 10 ohm resistor connected across them.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
"only difference is i have left out R3 and C2"
Without R3 and C2 the amplifier will oscillate and get very hot, this will activate SPIKE internal protection circuitry and make popping sounds. "I have tried putting in R4 and is now left off" Without R4 the amplifier will latch up to the power supply rail. |
| Pcm2902 "poping" | zdavesf | Digital Source | 1 | 29th January 2009 09:23 PM |
| Ok need amp help poping / cracking on left channel | intechpower | Car Audio | 2 | 22nd November 2008 03:05 PM |
| poping soundings | leander | Solid State | 44 | 1st November 2005 01:48 AM |
| Page generated in 0.08018 seconds (72.83% PHP - 27.17% MySQL) with 10 queries |
