Old 23rd June 2004, 04:17 PM   #681
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It's shipping out today
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd June 2004, 04:33 PM   #682
Peter,
Haven't seen mine yet either. Any word on Status?
Old 23rd June 2004, 04:52 PM   #683
Yours is shipping today as well.
As of tomorrow, all US and Canadian orders are shipped out. There are still some international left to be done, but as I provided substantial discount on shipping those (my actual mailing cost is about $50-60 CAD), I left them for last.
Also had some problem with locating those 1/4" plastic bushing for shaft extenders, but hope to get them today.
www.audiosector.com
Old 23rd June 2004, 05:11 PM   #684
zeno is offline zeno  Europe
As of tomorrow, all US and Canadian orders are shipped out. There are still some international left to be done, .....I left them for last.
I cannot wait!
More than 1000k away and last to receive a shipment!
Hope those extenders are not too floppy
Old 23rd June 2004, 05:21 PM   #685
Since you were the only guy from Belgium (and you showed some interest in that thread) yours is shipped out as well (last week)
www.audiosector.com
Old 23rd June 2004, 05:24 PM   #686
You're da man, PD!
Old 24th June 2004, 05:01 AM   #687
Send a message via MSN to porfi4ever
Thanks Peter, now I'm a happy man!!
Old 24th June 2004, 04:06 PM   #688
It looks like some of you might have already receive the chassis, so here some pointers as to assembling the amp.
I didn't drill the holes in side panels and in the 2 brackets supporting PCB; 400 and 600 holes to be drilled was beyond my scope.
The mounting holes for side panels are spaced exactly 1.00" from front and back and 0.60" from top and bottom. I would recommend 0.18 hole dia, but if you have problems with position it properly, you might go for bigger hole size, it doesn't really matter.
There are 3 holes to be drilled in mounting bracket (2.9 x 0.5 aluminum plates). Allt the holes should be positione centrally (widthwise). The one in a center is 1/8 and it's for a screw that attaches it to the copper piece. Two other holes are spaced exactly 1.125 from the center and should be tapped for #4-40 screws.
All hardware is supplied. Plastic standoffs are for PCB mounting (to those brackets). There are two #6 non magnetic screws to mount chips. I didn't provide any washers. If you think they needed, make your own choice here. I'm not using any washers.
There are 4 screws with integrated washers, those are to atach side panels to mid panel. All the other assembly is pretty much self explanatory. I recommend to retap all holes, to provide better electrical continuity between chassis parts. There are 4 sizes of taps used: 4-40, 6-40, 8-32 and 10-32.
Attach the wire to power the LED, before mounting rectifiers PCB, as later it's very hard. I'm using 68k resistor to provide voltage drop to the LED. The board doesn't have separate pads for that purpose (for some reason we didn't thought about it), so use your imagination.
I also forgot to add setting hole for the pot. You might drill it yourself, or simply brake off the notch on the pot.
The Grayhill switch has to be adjusted for 4 position operation. There are two stop pins that had to be inserted in appropriate holes. One pin goes into the hole that is placed right at the groove (in threaded part of the bushing), second pins is placed 4 spaces clockwise (from first one).
There are 2 decks and two poles, so you can switch input and ground (for each channel) separately.
Last position can be connected to the signal ground and used for muting (without a need to turn off the pot).
Shaft extenders mount to pot and switch with those plastic tubes. First you knock in the shaft (for appropriate depth) and later press fit into switch and pot shafts. This method does not provide rock solid connection, and when you force it one way, the knob will move through, but when you get use to operate it properly, you will not experience any problems.
After putting aeverything together (including wooden side panels) , you might readjust front and rear panel mounting screws to loosen up the tention on front panel, which maybe too hard to lift up.
I did not provide the ground attachment point on the chassis, and it's up to you what to use. In one example, I just didn't provide insulated washers on the ground binding posts, and it worked fine. You may only take the mains ground from AC socket and attach to the chassis. You may additionally run wires from CHG point on the PCB and attach it to the chassis as well. You might use 10 ohm resistors (or thermistor) to prowide some isolation between circuit and chassis grounds.
I guess I covered the basics and here the pic of the bottom side showing all power connections. It's very easy and straightforward process. Strat from amp PCB and run the wire through the hole in mid panel, choose proper length, cut and attach to rectifier's board.
Happy building
www.audiosector.com
Old 24th June 2004, 04:12 PM   #689
And here's the top view. As you see, I used switching attenuator. It consists of 10k Vishay S102 in parallel with 10k AN tantalum in series with a signal. The Sonic Frontieers attenuator (50 k with Holcos) provides shunting action. So basically, I have a fixed and not adjustable, series element (5k).
This configuration worked well for me in a past. BG caps had removed sleeving. I used here Apex Jr. toroid (Definitive Technology). Transformer was modified to provide double secondaries. It works and sounds very good.
There are 2 extra holes in copper heatsink, and they are used to run the wires between channels.
www.audiosector.com
Old 24th June 2004, 06:52 PM   #690
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Default assembly?
Peter,
I didn't realize we were going to have to do all this assembly...
from the way the parts were packaged, i thought i could just pop
it in the microwave - on high for about 10 minutes, and it would come out done!!
seriously though... how do i re-tap without stripping the holes?
Should i just see if assembly goes smoothly without re-tapping first?
Thanks once again for such a great job!
m.
Page generated in 0.13416 seconds (76.12% PHP - 23.88% MySQL) with 11 queries
