| Chip Amps Amplifiers based on integrated circuits |
How do amplifiers produce quality results using power supplies with only a bridge rectifier and filter caps? I know that the filter caps fill in the low spots in the rectified wave, but not completely... as the caps bleed off voltage to the output, their total charge falls, and can be calcuated, but I don't want to go read my textbooks right now to dig up the equations.
Anyways, since the DC won't be perfect DC if you look at it on a scope, how does the output signal of an amp powered by such a power supply not have a faint 120hz hum? Thanks. -Adam |
#2 |
PSRR (power supply ripple rejecion) built into the chip. However i use battery P/S so its not a problem.
ron |
| Amp power supply question | theAnonymous1 | Solid State | 12 | 30th August 2008 05:06 AM |
| 813 power supply question | Richard Ellis | Tubes / Valves | 6 | 14th December 2007 03:41 AM |
| Another Power Supply Question | soundbadger | Tubes / Valves | 12 | 10th October 2007 12:29 AM |
| Power supply question | HugoR | Tubes / Valves | 9 | 9th November 2005 08:34 AM |
| Power supply Question | Adam M. | Chip Amps | 10 | 4th May 2005 02:19 AM |
