Old 24th February 2004, 10:23 AM   #1
trancy is offline trancy  Slovenia
trancy's Avatar
Question tube buffer values
helo everybody....
maybe this is not real place for my question, but there is a half of schematic (joes amp) regarding chip amp...other half is tube buffer, and that is a part that i need...basicly....which values of resistors and caps can I use and of course which is the best transistor to use????
my english is bad....
thanks
too much is just enough
Old 24th February 2004, 01:28 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Trancy, that is Joe's commercial VBIGC (or something very similar).
Unless Joe stands out in the sun for too long, don't expect him to post his commercial secrets here .
The VBIGC that most people build is the DIY version that Joe 'gave' to us. details on
his site
and more on how I built mine Here
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 24th February 2004, 01:50 PM   #3
trancy's Avatar
"this might be some commercial secret" it was my first thing when i first time seen a schematic, but maybe, maybe.....you never know
Old 24th February 2004, 02:25 PM   #4
w00t is offline w00t  Singapore
his site
Hmm.. there's 2 tubes in your VIGC. Is this another secret?
Old 24th February 2004, 05:27 PM   #5
Nuuk's Avatar
No secret, just building separate buffers for each channel, as much for the aesthetics as anything else.
Old 25th February 2004, 07:09 AM   #6
trancy's Avatar
can i use that kind of buffer to drive a class mosfet amp (zen)?? should i modify something??
Old 25th February 2004, 08:40 AM   #7
Nuuk's Avatar
What you are really asing is will that buffer make a suitable preamp for another type of power amplifier.
I don't have enough experience of valve circuits to say for sure but I can't see why not. It may not be ideal but as Joe pointed out, it is a low voltage circuit suitable for beginners.
Old 25th February 2004, 09:02 AM   #8
trancy's Avatar
I
exactly....
Old 28th February 2004, 11:11 AM   #9
Shoog's Avatar
Default Shoog
If you go with this approach be very aware that you are introducing DC into the Zen as the buffers warm up. In mine it went from 20V at the speakers and dropped to about 100mv over about 30 seconds. This could be damaging to the type of speakers which tend to partner Zens. There are ways round this problem.
Consider using a FET buffer. NUUK considered this to be about the same in effect with none of the disadvantages associated with the Valve buffer.
Shoog
Old 28th February 2004, 05:39 PM   #10
Nuuk's Avatar
Just to clarify that, I still found some DC offset while the opamp buffer powered up but nowhere near as much (and for so long) as with the valve buffer.
It should go without saying that anything you build should be measured for DC offset on thge output and suitable precautions taken to protect the next item in the chain whether that be power amp and/or speakers.
Tube buffer before pre-amp/amp? Destroyer OS. Instruments and Amps 2 9th January 2009 08:09 PM
Cap values for tube mic psu studiochap Power Supplies 0 22nd October 2008 03:26 PM
Gainclone with tube buffer almu100 Chip Amps 2 20th February 2005 04:28 PM
Tube Buffer IGC - need help .... Will Chip Amps 22 21st November 2003 08:54 AM
Tube buffer NickC Tubes / Valves 3 9th May 2002 12:20 PM
Page generated in 0.16908 seconds (52.73% PHP - 47.27% MySQL) with 11 queries
