| Chip Amps Amplifiers based on integrated circuits |
ok, i recently made a fully functional lm4780 PCB*. i plan to mod it a bit for a high power subwoofer amp. i would like to know if there is any interest in such.
i may also make stereo boards if interest exists. it will likely be about a month before boards are constructed. as of now, the plan is for a monoblock subwoofer amplifer with volume adjust and crossover adjust. currently planned crossover is 2nd order with bypass option. from my experience though, if you buy the board you will still need to be competent with a soldering iron -- the pins are really close on these chips. i may make a few mods on the boards, so people can have options. like a board without crossover, or a board for 3 lm4780 for extra power, ect... depending on demand. *this PCB is however unsuitable for widespread use as the caps are too close to the chip mounting holes and the input holes are too small. otherwise the board works. you can get the board mounted, but it took me about 30 minutes to do so. the board i plan to build will be larger and will not have these problems.
if only it could be used for good, not evil... |
#2 |
Hi Chris, I'm interested with your monoblock subwoofer pcb as i'm planning to build an amp for my subwoofer speaker. I think Lm4870 is good for that purpose, although i have tried stk4050v for my other project, i'd like to try the Lm's
Regards: Junfer:
JGF |
#3 |
I would be interested in a couple of boards as well
Leo |
#4 |
are you interested in a dual lm4780 (bridged-parallel) single lm4780 board (bridged or parallel)? since i'll be making the boards locally, i plan to be able to tailor the PCBs to the user a little bit more.
i also plan to expand on the dual lm4780 pcb to a triple lm4780 PCB, if there is any demand at least. and i may be making some boards for lm3886tf / lm3876tf / lm2876tf as i will be making an amp for a friend using these chips. IIRC the pin spacing for the tf packaging is a little off compared to the t packaging.
#5 |
Hi Chris, I'd been trying to find where to buy lm4780 on the Web but no luck, where do you buy your's, I'm in Canada, also i'm interested with the Lm3886 pcb project "dual"; Regards;Junfer
JGF |
#6 |
I would be interested in a couple 2 channel boards, and a brindged for sub use.
#7 |
i actually got my chips as samples during the time when they were samples only. i'll look around and find where you can get some otherwise.
#8 |
I would use them for sub's, two boards for the bridged version. And if you could help out with (where to get) the lm's ? That would be very nice,
Leo |
#9 |
Yes, would be interested in 2-3 boards. Please keep us posted.
Wishlist: single chip, generous holesize for larger caps with thicker leads, alternate pitch holes to allow smaller caps. |
#10 |
Hi!
I would also be interested in a couple of boards depending on the price (subwoofer mono block) Cheers! /Christopher |
| PA150 PCBs, is there any interest | CJ900RR | Chip Amps | 40 | 16th April 2009 05:25 PM |
| Interest in dual regulator LT1083 pcbs? | h_a | Group Buys | 32 | 20th August 2008 03:36 PM |
| Survey of interest in PCBs of Mauro's designs | Russ White | Chip Amps | 2 | 15th June 2005 07:30 PM |
| about the lm4780 PCBs | diysmartdeep21 | Swap Meet | 0 | 22nd February 2005 05:39 PM |
| about the lm4780 PCBs | theChris | Chip Amps | 18 | 31st August 2004 05:54 AM |
| Page generated in 0.08984 seconds (82.94% PHP - 17.06% MySQL) with 10 queries |
