| Chip Amps Amplifiers based on integrated circuits |
Well I want to make a Subwoofer using mentioned chips, I have already made the main amplifier using TDA7386 which happens to be a superrrrrr chip 4 channel 45 watts each, now for subwoofer I have the choice of above mentioned chips but does anyone have the idea how to operate them with 13.2 Volts of Car bettery, as the data sheet of these chips do give a hint of single supply biasing but required voltages to bring the chips into ACTION are not,
CAN ANY ONE PROVIDE HELP??? |
#2 |
LM3875 LM3886 ?
Take 2 batteries and bind 2 different poles together, this is your GND. Now you have - 12 / + 12 v if you measure from ground to the other posts. |
#3 |
Guess I messed up things please read as LM3875, LM3886, and LM47xx, joining two batteries is a good idea, I knew it already as u all know its kinda difficult to place an extra battery in the car even if u put it how would it be charged, so any other solutions...............
Any one with some other solution? |
#4 |
Are there any bright minds out here in this formu who could solve this problem of biasing an LM3875 or LM3886 with 13.2 volts of car bettery?
| 4780 single sided pcb redesigned | gmphadte | Chip Amps | 24 | 25th June 2011 05:09 AM |
| Single sided 4780 PCB ready | kuldeepsingh | Chip Amps | 8 | 1st April 2007 08:56 AM |
| 4780 3in1 single sided | gmphadte | Chip Amps | 5 | 9th March 2006 03:02 AM |
| Stereo Single 4780 | traw | Chip Amps | 3 | 16th February 2006 12:39 PM |
| Page generated in 0.10330 seconds (74.56% PHP - 25.44% MySQL) with 10 queries |
