| Chip Amps Amplifiers based on integrated circuits |
I just wanted to check if the much vaunted 150VA supply per chip figure is still the consensus. I have a couple of 20-0-20 5A transformers that I would like to make a pair of bridged IGCs using LM3875's from, but only if some have experienced good results with 100VA/chip.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
Well since the LM3875 is limited to 5amps... I doubt you would have a problem.
I think the 150Va thing is more when using a 25-30V transformer. At least that’s what I’ve come to think from reading threads here. (I’ve only built one of these things, but it sounds pretty good with only a 85VA 18V transformer per chip.) |
#3 |
i'm using a 125VA 2x18V toroid per channel. Works like a charm.
#4 |
i'm using a 50VA 2x18V toroid per channel. Works like a charm.
#5 |
i'm using a 120VA 2x25V EI for 2 channels. Works like a charm.
#6 |
I don't have a LM3875 but I hear people say it works like a charm
#7 |
pjotr, you win
#8 |
No, Circlotron wins, 1.2A per channel’s rail.
#9 |
for testing I use item # 1013 from B.G. Micro (they still have them)
2 Basler transformers (each 20 V AC and 1.2 A) per chip this set up sounds extremely well at low volume!!! extremely well! By the way any cheaper?? they cost $2.49 each and are the best I have ever bought. I also used them (with the D1213) for a cheap dc power supply! and for $30 (including components and small enclosure) kit I have a adjustable power supply that gives 2A and aprox 28 volts DC. yes the 2 panel meters (voltage and Amp.) are included! J-P |
#10 |
How are you guys having success with such small transformers? I tried 2 channels of LM3875's with a single 160VA @22-0-22 and it clipped bad when I tried to crank it up. I installed a second 160VA transformer, one for each channel, problem solved. I can get full power out of it with no distortion.
I must be missing something. Mark |
| FS: New pair of 100VA Transformers; 36VCT 2.8A | dozer | Swap Meet | 0 | 9th January 2009 12:41 AM |
| WTB 2X50V 100VA Toroid transformer | gaborbela | Swap Meet | 1 | 22nd December 2008 08:07 PM |
| This may be good for a Gainclone kit (LM3875) | mudihan | Chip Amps | 0 | 24th August 2007 04:26 AM |
| Whats a GOOD LM3875 chip amp circuit? | matt_uk | Chip Amps | 5 | 14th November 2003 10:23 PM |
| Page generated in 0.23401 seconds (35.50% PHP - 64.50% MySQL) with 10 queries |
