| Chip Amps Amplifiers based on integrated circuits |
I'm pretty new to building audio amps and I just received a few LM3875T's the other day. I'm going to build the typical schematic found in national's datasheet for the chip. My question though, is what type (and specs?) of transformers should I use for the power supply? I want to power two LM3875T's with the powersupply if this makes any difference. The schematic i'm planning on using is attached. Thanks! Regards, Matt |
#2 |
You need a transformer that has either two secondaries, 18-25V, or a center tapped secondary, 18-0-18 to 25-0-25V.
It should ideally be at least 300VA for both channels, but some people used smaller for lower volume applications. My recommendation is 400VA as there is a very slight difference in price between 300 and 400. http://www.partsexpress.com/pe/showd...D=123268&DID=7 that would work also plitron model # (www.pliton.com) : 077014201, 757015201 (and others) will work .. |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 11:44 AM |
| FS: Transformers | alexcd | Swap Meet | 0 | 19th November 2008 09:34 PM |
| WTB : Transformers | korben69 | Swap Meet | 1 | 27th June 2008 07:05 PM |
| my first amp (transformers???) | fitchmicah | Chip Amps | 5 | 7th January 2007 08:26 PM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 12:38 PM |
| Page generated in 0.32575 seconds (10.66% PHP - 89.34% MySQL) with 11 queries |
