Old 20th February 2004, 11:46 AM   #1
Default Using cascoded JFETS to bias op-amps into class A
Just been reading up on this method-can someone please confirm my understanding:
1. Gate of JFET 1 to -V
2. Drain of JEFT 1 to -V via Resistor R
3. Source of JFET1 to drain of JFET2
4. JFET2 source and gate to -V
Choice of bias current: Choose a current equal to 10% of the maximum ouput current of the op-amp (which it seems should have a buffer following it).
Choice of JFET-Select any N-channel JFET such that its Idss exceeds the bias current required (10% of Iout max)
Choice of R: Select such that V/R provides required bias current
Idss-Is it important to match these for the two (L and R) channels and if so how is this done?
Thanks for any help.
Ryan
Old 24th February 2004, 03:01 PM   #2
Further thoughts and questions:
Seems that most DIYers use a cascoded JFET arrangement without any current setting R and simply use the JFET at its IDSS.
This seems to have the benefit of maintaining a high input impedance at the following stage (normally a buffer), which presumably would be compromised by the use of a R with the JFET.
However, it does seem that the use of an R would isolate the output of the amp from the high capacitance of the JFET, hence my question:
Anyone know of a low capacitance (10pf or lower) JFET with an Idss of 5mA or less?
For reference, the circuit I'm refering to is at
http://www5.head-fi.org/forums/showt...hlight=cascode
See the attachment in the post.
Old 24th February 2004, 06:12 PM   #3
jcx is offline jcx  United States
it seems cascode fet ccs loading has nearly a cult status among the headfiers
in http://www5.head-fi.org/forums/showt...639#post355639
i attempt to point out weaknesses in the the party line there and show some simple alternatives
a few references:
http://www.vishay.com/fets-small-signal/ssfanp
AN102 "JFET Biasing Techniques" Figures 7, 15, 16 and associated discussion should be required reading in addition to the obvious AN103 "The FET Constant-Current Source/Limiter"
Old 25th February 2004, 06:54 AM   #4
Thanks, useful.
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
how to bias Halton Precision amps in to class A rhythmdiy Solid State 5 12th December 2008 03:59 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
Page generated in 0.08986 seconds (69.50% PHP - 30.50% MySQL) with 10 queries
