lm3875 at 94V - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 27th January 2016, 10:00 PM   #1
Default lm3875 at 94V
hi i dont have enough parts at stash,run out of good transformers and hi curent regulators ,and in sort of hurry to finish amp.at +-45v dc is it better to drop 10v with 2sc1943, 2sc5200 or put them in output(dont care i need pair more i have stash) ,sort of using 3875 as first stage but on 94v still ? i know neither solution is good but i need to have spare amp in few days from now,so cant wait for parts to arrive.
i think is lot better to put in output but want to make sure i didnt miss something.
Old 28th January 2016, 12:43 PM   #2
ok this should work, i will try this afternoon to make then post if it is working and why not,but i will use 3875
Old 28th January 2016, 01:26 PM   #3
Absolute maximum ratings are 94V rail to rail when no signal is present and 84V rail to rail when a signal is present.
Your measured 94Vdc may not be worst case.
How high could that go when mains is at it's highest?
I suggest that you build a non feedback voltage regulator using a Zener and emitter follower (Pass has examples) to bring your supply down to +-40Vdc, or lower.
A capacitance multiplier could also drop significant voltage to enable your chipamp to survive.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th January 2016, 07:36 PM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
+1
Here's a good intro to zener regulators: Voltage Regulators, Different types, Working principle, Design
Tom
Modulus-86: Composite amp achieving 0.000067 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com - Engineering : : Done : : Right
Old 28th January 2016, 08:03 PM   #5
hi, now in another doubt, option 1 or option 2
Old 29th January 2016, 08:44 AM   #6
Left works. Right does not work.
regards Andrew T.
Old 29th January 2016, 11:34 AM   #7
sry , my mistake i was in hurry and just made mirror of top image.
will this work
Old 29th January 2016, 11:37 AM   #8
Now both work.
Did you look at Pass?
regards Andrew T.
Old 30th January 2016, 04:10 PM   #9
it burned resistor on negative side, and for few seconds there was 1.5v on output. i cant find Pass labs version of this.
Old 31st January 2016, 05:29 PM   #10
well managed to put 84 volts on -ve somehow, and burned both 3875 ,still not sure how. found stk module which works on 90+ volts.
LM3875 ? Philfr Chipamp 8 31st January 2016 08:34 AM
My first lm3875 scrazy Audio Sector 4 5th December 2012 06:16 PM
Lm3875 Help Tristanc1 Chip Amps 22 25th July 2011 06:54 PM
yet one more lm3875 karma Chip Amps 8 27th July 2005 09:48 PM
lm3875 help karma Chip Amps 7 20th December 2003 11:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
