Amp dies off after some time of operation - diyAudio
Old 13th January 2016, 01:24 PM   #1
Default Amp dies off after some time of operation
Hello experts.
I have a Warwick BC80 Bass Amp. It has a inbuilt function for compression.
The amplifier works properly when it turns on.
The power stage is built around a TDA7294. There are 2 symmetrical 130 Ohm/2 Watt resistors on the circuit which seem like some kind of bias resistors. One of them operates normally, but the other one heats tremendously.
As the amplifier turns on it operates properly, it's heating starts and over a span of around 2-3 minutes the compression function starts kicking in slowly and the amplifier is muted at the end.
But I also observed that the resistor heating continues even after it is muted. And the amplifier will only function after it is turned off and after the resistor cools down.
How should I solve this problem? I am unable to find any schematics online either.
Awaiting your replies.
Thank you!
Old 13th January 2016, 03:36 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Check Q201/202. Those resistors, R201/204 feed the + - supply to the pre amp and effects. Maybe a leaky decoupling cap?
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 13th January 2016, 03:52 PM   #3
johnr66 is offline johnr66  United States
Large resistors such as these are sometimes used in the supply rails for a voltage drop for some other part of the circuit. After looking at the datasheet of the TDA7294, I don't see where they would be needed for its function. Does the IC get very hot when the problem occurs? Comparing the signal entering and exiting the IC could prove it guilty or innocent of the problem. This would require some gear to test with, such as an oscilloscope.
A clear picture of the circuit board, both sides if possible, might help us.
EDIT: well never mind. It looks like someone with a schematic has chimed in.
Old 13th January 2016, 04:05 PM   #4
Can you post the schematic please? Would be easier for me to debug.
The IC was not getting hot. I will recheck again. What should I look for while comparing I/O waveforms of the IC?
I have access to a signal generator and a scope.
Old 14th January 2016, 02:06 PM   #5
I suspect the IC is not the culprit in this case. I guess the issues are in the circuits prior to the power amp IC as JonSnell alluded to. Hopefully he or someone with better knowledge of this amp can help you.
Explaining the operation of a VAS in this amp guitar_joe Solid State 9 20th September 2007 11:49 PM
Buffalo Ironworker punches & dies mobyd Parts 0 10th May 2006 12:25 PM
Diac & Triac relay operation? AndrewT Solid State 2 16th February 2006 01:35 PM
TOPWARD MODEL 605 operation manual & Schematic ku5355 Tubes / Valves 0 16th December 2005 10:40 AM
Amp crackles and dies DD_Davo Chip Amps 32 22nd March 2005 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
