Old 15th November 2004, 12:01 PM   #31
Send a message via Yahoo to mikelm
Gosh - what would unfriendly advise be like...
gengcard
If you are still inspired to try this the CCS transistor has to be a power transistor and on a heatsink aswell as the chip amp.
mike
Old 15th November 2004, 02:01 PM   #32
Thanks for advice. I will change it to power transistor or MOSFET soon.
Could you suggest me which transistor should be instead of MPSA18? In Thai semiconductor market has many power transistor and MOSFET. It's hard to choose one.
Old 15th November 2004, 02:35 PM   #33
Banned
2n3055.
You can find them everywhere, and they are cheap.
Old 16th November 2004, 01:11 AM   #34
2n3055.
Thank you Carlos for your advice. I'll find it one.
Old 25th July 2007, 10:56 AM   #35
Archwn is offline Archwn  United Kingdom
Default LM3875 Class A
How about using LM337 as a CCS to bias 0.5A to 1.5A current.
In this case the resistor wattage could be only 1 - 2 Watt.
This could also be replaced with LM317 or LT1085 with few adjustments.
This one has been tested with around 0.5A bias current with hours of music with no significant dc offset changes from normal operation mode. It comes with switch between class AB and A for quick comparision listening test.
http://www.htg2.net/index.php?topic=20586
I can confirm that it changed how LM3875 in normal operation sound. With low volume, few mins of burning in, not so complex music, it is more obvious, I was stunned. The sound is more smooth, more focus, more depth in soundstage but some how narrower. The sound is more like real performance to me which I like but I also notice that the details is some how dropped which I tried to improve. (I'm a newbie in electronics by the way.)
One thing I suspect is the capacitor used in CCS part. this might damp the sound so the detail is not good. I would try to take them off and do the listening test again.
Every comments on how to improve this impliment are at most welcome as this one is just a conceptual study on biasing power chip amp into class A.
Old 25th July 2007, 10:59 AM   #36
the board.
Old 9th August 2008, 03:26 AM   #37
vizion is offline vizion  United States
Default Class A, folks
Hello Guys,
i just wanted to revisit this thread. How did Class A experimentation go with chip amps ?
Old 10th May 2011, 10:20 PM   #38
Does the balanced gainclone idea leave Class A when amp is turned up past the wattage the bias point is set for ?
Old 11th May 2011, 04:47 PM   #39
I was just reminded by someone that this thread, which I began many moons ago, existed and having just moved back from the USA after five years I found in my stored possessions in the UK the same 1/2 built amps which I referred to here so it may be I will check out this idea.
Having just re-read the thread I am not surprised that carlos's resistor biased amps lost their "live", dynamic sound, the amps o/p circuits would have to have to work to switch the current to drive those resistors. The active current sources should be "invisible" to the signal so I would expect the circuit implemented this way to sound different and hopefully more effortless & dynamic.
Of course after the 1st watt or so the amps will go into AB but 1 watt is quite loud so any switching noise should be virtually imperceptible.
mike
SE to Balanced tube preamp idea hollow_man Tubes / Valves 33 1st October 2009 06:44 PM
Balanced compound-IGBT power amp idea revintage Solid State 10 21st January 2008 04:27 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
120ish watt Gainclone? Mach_Y Chip Amps 1 29th April 2003 02:19 AM
Page generated in 0.13415 seconds (68.12% PHP - 31.88% MySQL) with 11 queries
