Old 16th February 2004, 01:05 PM   #1
Question Transformers and grounds
I am building a lm3886 subwoofer amp, and want the thing to look professional. So, I bought an aluminum plate from Science and Surplus (a local surplus store), and assembled the thing on it.
IS it safe to have the transformer mounted directly to the aluminum? I know that nothing happens when it is touched.
Here are the pictures of the unit. The amp is not done and I have to get around to drilling the hole for the switch. All thats on there is is the trafo and power supply board.
Is this safe?
Old 16th February 2004, 01:40 PM   #2
hacknet is offline hacknet  Singapore
i guess its perfectly fine aslong as you earth the casing to be safe.
Old 16th February 2004, 05:21 PM   #3
peterpan73's Avatar
Send a message via Yahoo to peterpan73
Default Crazy transformer idea
Hello,
I am wondering whether its possible to use a welding transformer to power up a rack full of PA Amps (say 5 to 10KW RMS) as welding trannies are cheaper in my country, produces a large current-350 to 1000Amps at a low voltage -20 to60V.iIf its possible what kind of rectifiers and filters should I use.
I like this idea to keep down costs. The amps are for live sound reinforcement.
Please let me know at the earliest.
Desperate peterpan.
Thinking is the Hardest Work there is. Which is the probable reason why so few engage in it.
Old 16th February 2004, 09:14 PM   #4
Yes, if it is center tapped.
but nowhere ar you going to find a 1000A rectifier, most likely not even 350A.
-Mike
Old 17th February 2004, 02:27 AM   #5
peterpan73's Avatar
Default Welding transformer
Hey thanx there Mike,
BTW... I have been thinking about the very high current rectifiers and am thinking of using industrial rectifiers either from www.abb.com or www.irf.com.
Would you be kind enough to select a good rectifier for me from these places. There are too many of them there and I am a bit confused of the right one add to that the fact that I'm technically competent too. and yes the filter too please!!.
Peterpan
Old 17th February 2004, 02:30 AM   #6
peterpan73's Avatar
Default correction
incompetent I mean!!!
Peterpan
Old 17th February 2004, 10:14 AM   #7
runebivrin's Avatar
Send a message via MSN to runebivrin
Well, you're gonna need a pretty hefty bank of capacitors to stabilize that. It might be a simpler idea to use separate bridges and cap banks, connected to a single transformer.
Rune
Do wizards use spell checkers?
Old 17th February 2004, 12:52 PM   #8
Could you tell me the exact specs of the transfomer?
Old 17th February 2004, 01:05 PM   #9
peterpan73's Avatar
Thanx there Mike,
Looks like we're online... why don't we chat about this... my YahooID in yahoo messgr is patrick_pugh2000
Patrick
Old 17th February 2004, 01:11 PM   #10
peterpan73's Avatar
Default Tranny info
OK the tranny is 230VAC Pri, 20-0-20VAC Sec, 350Amps
Isolating L and R grounds??? wrestlinguy Parts 5 13th June 2006 04:50 PM
Multiple Grounds Wynand Chip Amps 12 4th December 2005 12:38 PM
Should grounds go like this? leander Solid State 18 18th November 2005 12:55 AM
PSU sharing grounds neutron7 Parts 2 5th March 2005 01:23 AM
Sequence in which grounds are connected Saurav Tubes / Valves 17 7th July 2003 03:17 AM
Page generated in 0.10238 seconds (78.66% PHP - 21.34% MySQL) with 11 queries
