Old 18th February 2004, 08:27 PM   #31
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Harry,
There is always some bias current flowing into (or out of, depending on the type) the inputs of an opamp. If that current has no path to ground, the input node starts to float up (or down). Use a resistor to gnd (not too large, as small as possible wrt the source resistance) and you're home free.
And yes, you can share the input cap among parallel amps.
Jan Didden
Old 15th August 2008, 11:22 PM   #32
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Amp Feedback
Originally posted by wrenchone
The circuit in the attached file labeled "A" is the one discussed in this thread so far.
The disadvantage of this approach is that C1 must be relatively large,
and it does see some reverse bias when the output swings negative.
I would try using an Oscon for C1 in circuit A,
as they are supposed to tolerate substantial reversal without ill effects.
I first learned about the Circuit labeled "B" over 20 years ago in Audio magazine.
I use this circuit ("B") in my projects almost always instead of the conventional one ("A").
one new way, for me, to deal with DC offset feedback
thanks
lineup
Feedback capacitor MarcH Parts 12 1st December 2009 10:05 PM
How to minimize output offset drift w/o servo?? Leolabs Solid State 14 10th November 2006 02:27 PM
VAS to LTP Feedback Capacitor Question (A bit like in the A40) primalsea Pass Labs 1 15th November 2005 10:31 PM
Capacitor for in the feedback. JoeBob Solid State 1 21st May 2002 10:32 PM
Page generated in 0.09139 seconds (69.30% PHP - 30.70% MySQL) with 11 queries
