Dear viewers,
Hope one of you can assist with a relatively simple request by upgrading this
small Tripath amp from SMSL by adding or replacing two DC decoupling caps next to the output filter inductors with a pair of 330uF/25V Panasonic SEPF(Oscon).
My board is from May 2014 and SMSL left two locations for these decoupling caps open, where others mentioning replacing the existing caps with Oscons on exactly the same location... so on this board you just can add these Oscons while there is no need to replace another decoup cap....
I also passed the volume pot but I am not sure if this is a good idea with
a T-amp... so direct wiring without using pot from the RCA entries to the
first stage after the pot..
