TDA2009 PCB design check - diyAudio
Old 2nd November 2015, 05:32 AM   #1
Default TDA2009 PCB design check
Hey all,
I'm trying to build an amp based on ST's TDA2009 chip in bridge mode. I've used the bridge circuit from the datasheet.
I've previously built the circuit on a pcb but the chip went hot fast. I checked the connections and there were no short circuits. I'm not sure what went wrong.
I've redesigned the the pcb and I'd like to get some help if I did it right this time. All ground points are connected to a ground pour. Images are in the attachments
TDA2009 A amplifier help milix Chip Amps 8 15th December 2008 08:53 AM
PCB Check Khron Chip Amps 48 28th May 2006 10:55 PM
Can i use TDA2009 as gainclone himanshuraval Chip Amps 1 15th November 2004 01:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
