First amp build, any problem with other parts selected?
Old 1st November 2015, 06:40 PM   #1
Blank space is offline Blank space  United States
Default First amp build, any problem with other parts selected?
Just placed order for an Audiosector premium dual mono kit. Here are other needed parts I selected and want to make sure I'm not choosing poorly.
I'm considering,but haven't chosen an input selector yet.
Any help choosing an input selector would be appreciated.
I intend to mount LED's on rectifiers and am thinking of positioning in a way so they can be used as a power on indicator thru front panel. Ideas?
Chosen due to Noble pot NLA I assume?
More Information Page
Chosen due to higher power option noted on DIY forum: x2
Avel Y236750 330VA 25V+25V Toroidal Transformer
761-18/003 Qualtek | Q300-ND | DigiKey
LN222RPX Panasonic Electronic Components | P612-ND | DigiKey
Sure Electronics Mini Gold Plated Insulated 5-Way Binding Post Set 2 Red 2 Black
http://www.parts-express.com/parts-e...pair--091-1120
Old 2nd November 2015, 10:55 AM   #2
Philfr is offline Philfr  France
Sure Noble are better vs ALPS, look at Tocos RV24..
Potentiometers | Hifi Collective
120/160 VA transformers are enough..
binding post are fine..
RCA are better with ptfe insulation..
IEC socket is fine, but maybe you can choose a simple and add a switch at front panel..
For led, use two led (one for channel) like it's show at Audiosector psu board..
Phil.
Old 3rd November 2015, 03:45 AM   #3
AlexQS is online now AlexQS  United States
I have those exact transformer you reference above, paired to an Audiosector kit. It's way more transformer than you need. I assume you already know to not run 4 ohm speakers with 25 + 25, you can only run 8 ohm speakers.
This one is significantly less expensive, and I believe just as good: AS-3225 - 300VA 25V Transformer - AnTek Products Corp
As above poster mentioned you only need 120 or 160 VA, especially since it will be a dual mono. I'm getting a 300VA 22 + 22 for my next project. Only reason for a 300va is because it will drive 3 amp boards, otherwise I would have gone for a 160 or 200, still more than enough for 1 channel.
One last thing, you mention wanting to put an indicator light on your front panel, cool. I'd suggest don't break the perforation between the power and amp board. It may be tempting to move the power board away, and easier to get that led near the front panel. To me the benefit of being able to use super short wires like in Peters instructions is the way to go. I separated mine, then moved them back next to each other later. No big deal to break the perforation, but if would look more tidy if I had never separated them.
Have fun.
Old 3rd November 2015, 02:14 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
First amp build, any problem with other parts selected? Send a message via AIM to Peter Daniel
Technically, 120 or 16VA0 transformer would be fine, but if you want achieve better sound, go with 300VA unit if your enclosure allows it, 220VA would be absolute minimum.
I didn't try neither Antek not Avel, but the latter seems like a better product.
The LM4780 chip in parallel configuration will work perfectly fine with 25V transformer and 4 ohm loads.
Higher voltage tends to sound better.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Old 3rd November 2015, 04:51 PM   #5
Higher voltage tends to sound better.I'm all for that....and I got a little concerned when I checked specs of my BAMTM's I built and my Advent Heritages I converted to Dayton 8's a couple years ago and saw they were both in the 4 to 6 ohm range. I guess I'll have no issue running either of them with my build.
Old 3rd November 2015, 04:59 PM   #6
My mistake,.. I didn't look closely enough, and I assumed it was the LM3875
First amp build, any problem with other parts selected?Hide this!Advertise here!
FS: F5 amp parts for build mravlca Swap Meet 9 30th January 2013 11:31 AM
What amp can I build with these parts?.... bugust Everything Else 1 1st October 2012 09:46 PM
Morel MW166 4 pieces, selected&NEW! barnabamax Swap Meet 0 20th June 2011 05:58 AM
Homemade AMP Parts List Problem Paprika Parts 10 30th March 2010 06:11 PM
what amp to build with these parts ? Groundloops Solid State 1 28th May 2004 04:24 PM
