OP amp phono preamp gain
Old 6th October 2015, 03:37 PM   #1
stevovee is offline stevovee  United States
Send a message via ICQ to stevovee Send a message via AIM to stevovee Send a message via MSN to stevovee Send a message via Yahoo to stevovee
Default OP amp phono preamp gain
Just wanted to double check that I am calculating this gain right.
There are two gain stages
so the first one has
(3320/150)+1 or 23.1333 gain and the second gain stage has the same
so multiplying these tother
23.13*23.13=534.9969
and then converting this to dB using this calculator
Decibels to Voltage Gain and Loss convert calculation conversion amplification amplifier electronics - sengpielaudio Sengpiel Berlin
gives me a gain of 54.5dB
am I doing this correct. The reason I ask is that I just tried an off the shelf phono that is supposed to have 40dB of gain but seems to have much more than my DIY phono that I am calculating has 55dB
Old 6th October 2015, 03:53 PM   #2
realized i forgot to attach the image of the phono preamp design.
Old 6th October 2015, 04:46 PM   #3
rayma is online now rayma  United States
Originally Posted by stevovee View Post
gives me a gain of 54.5dB am I doing this correct.
Yes, for low frequency gain. Then in the midband you lose 20dB due to the RIAA network,
so the nominal signal gain is 34.5dB. So, the other preamp has 5.5dB more gain.
This one will likely have much better RIAA response and lower noise, though.
Old 6th October 2015, 04:56 PM   #4
R.I.P.
If you need the extra gain, then put it all into the first stage. Try 75r instead of 150r.
But don't put in too much, or you'll use up all the gain bandwidth product.
regards Andrew T.
Old 7th October 2015, 11:40 AM   #5
jcx is offline jcx  United States
put at least 1 pole of the RIAA roll off in the 1st amp feedback and you don't have a GBW problem
and get dynamic headroom benefit too for mistracking, pops, ticks
does cost a extra RC low pass to correct the Zero introduced by the non-inverting low pass filter's transfer function flattening out at unity gain
the flat gain blocks with passive RC EQ in the middle is the most demanding of op amp performance compared to intelligent low pass frequency shaping in the feedback network(s)
it really seems wrong that those suspicious of feedback amp performance tend to select this worst case topology
OP amp phono preamp gainHide this!Advertise here!
Phono Amp Gain vs. Preamplifier Gain dbxdx5 Analogue Source 1 15th June 2015 09:32 PM
Using a phono preamp instead of an op-amp jonciukelis Digital Line Level 4 1st August 2014 05:03 PM
Hagerman Bugle Phono Preamp with upgraded Op-Amps (OPA2132/LT1028/OPA627's) dtm1962 Swap Meet 4 29th March 2010 04:22 PM
Bugle phono preamp with gain and source impedance adjustment. badduh Analogue Source 7 18th December 2009 07:51 AM
The best phono preamp on op-amps? djaleksei Analogue Source 63 17th November 2008 12:59 AM
