Sure electronics ST508 amp: AA-AB32186 - diyAudio
Old 4th October 2015, 04:16 PM   #1
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Default Sure electronics ST508 amp: AA-AB32186
Hi
We are making some mobile speakers. For the electronics we want to use a 2x4 miniDSP for signal processing and 2 of sure electronics amps based on the ST508 chip(model AA-AB32186)
But so fair we canīt get any useful output from the amps. maybe a watt or two.
The problem seems to be that MiniDSP low output and we therefore want to increase the gain amp.
Iīve looked at the datasheet for the amplifier chip. But i cannot find out how to increase the sensitivity of the amp.
Can you guys and gals help me out?
Datasheet for the chip
http://www.st.com/web/en/resource/te...CD00003546.pdf
Would be so grateful for some help.
Old 4th October 2015, 04:37 PM   #2
The signal from the DSP and the amplifier is analog, right? Then put a voltage amplifier between the DSP and the amplifier. A simple op amp based circuit would suffice. Do some back of the envelope calculations to determine proper gain structure.
These digital amplifier boards sure do boast of high performance in a small space with an attractive price. Too good to be true? Not really hi-fi, I guess. I can't deny that I've been tempted to buy one of these units and see how well I could make it work.
Old 4th October 2015, 05:51 PM   #3
Yes. It is an analog signal.
I simply have no clue about how i would go about designing something like that.
I can do smaller modification or buy something pre-made to put in between. But what would something like that be called?
Old 5th October 2015, 04:34 AM   #4
AlexQS is offline AlexQS  United States
BTW, I'm using miniDSP nanoDigi. Your miniDSP 2x4 is a little different, so I can't give you specifics, but look into the literature about your 2x4 -because I think there's a jumper you can move to change your output voltage from 0.9V to 2V. That may help your situation. Also when you plug in miniDSP to your computer, do you have gains in the menus set right? I have my input about -10dB as to not clip the DAC, and give me a little headroom for any PEQ gain. On the output tab, the least efficient speaker runs at full volume, and the most efficient speaker has a few -dB to pad it down to match. Check miniDSP forums for more if this area is problem.
Old 5th October 2015, 08:02 AM   #5
On the 2x4MiniDSP the jumpers are for the input side only. And with the gain cranked up as much as the software allows. Then it seems to be using roughly 5-10% of the amps potential.
Old 5th October 2015, 08:04 AM   #6
Iīve done a lot of experimentation. From what i can gather i need some kind of hardware solution. some kind of modification or extra hardware.
Old 5th October 2015, 09:42 AM   #7
Mark Whitney's Avatar
How about measuring the outputs of the miniDSP or testing the amps with a known source. On paper this set up should work just fine without any extra gain.
Regards Mark.
Old 5th October 2015, 09:54 AM   #8
Driving the amps directly from the bluetooth module is really loud in comparison to what i get, when the signal goes though the MiniDSP. Which means the amps should be okay.
Sending the MiniDSP signal to my Denon amp gives a great result too.
So in some weird way that i canīt figure out. there is a mismatch between the 2 components.
Sure Electronics AA-AB33182 [4 x 100W] Class D Audio Amplifier Board +27V DC Power... fualcr Swap Meet 5 11th December 2014 08:32 PM
Sure TK2050 AA-AB32186 jedimind0 Class D 3 11th June 2014 09:12 AM
Heathkit AA-40 or AA-121 panheadchopper Tubes / Valves 1 5th February 2011 03:51 AM
FS: HIGH END Home Audio lot..Opera Louspeakers, Triangle Comete, AA Primo, AA, etc. JiggaD369 Swap Meet 6 22nd August 2008 01:32 AM
1959 Pilot AA-908 Amp into Guitar Amp aronaut Instruments and Amps 6 19th March 2008 08:38 AM
Copyright Đ1999-2017 diyAudio
