Tda7297 vs tda1554
Tda7297 vs tda1554
Old 20th August 2015, 01:44 AM   #1
Turbogrill is offline Turbogrill  United States
Default Tda7297 vs tda1554
Hi
I am looking to build a very simple amp with a few components.
Both the TDA1554 and TDA7297 seem to fit very well.
But I can't decide which to pick, they are pretty similar.
Anyone have any pros and cons?
Old 20th August 2015, 02:47 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
No experience with the TDA7297, some with the TDA15xx devices. If your speaker might dip below 8ohms I'd go for the TDA1554 as it has more output current (4A vs 2A).
If you're feeding them direct from something like a smartphone as a source then they might both benefit (in subjective SQ) from having an input buffer to raise the input impedance - they present 30kohm natively.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 20th August 2015, 03:51 AM   #3
Thanks! That makes sense. I will stick with the TDA1554.
How about the TDA8655, they seem to be very similar only that the TDA8566 is little better. More gain, more power and higher impedance.
Old 20th August 2015, 04:01 AM   #4
Destroyer OS is offline Destroyer OS
Destroyer OS's Avatar
The 7297 doesn't struggle at all with a 4ohm load. I've had my demo playing on Piega Premium 5.2's (preferred over Byston 3BSST2), which are 4 ohm.
Also it played some Totem Elements (4ohm) with some gusto in the higher range the McIntosh at the shop didn't, while simultaneously showing the weakness of the highs in the speaker (to some this would be a benefit) and defunct streaming technology they were using...
Tda7297 vs tda1554Hide this!Advertise here!
Filter after TDA1554. derekgabs Car Audio 16 9th November 2013 10:13 PM
few questions about TDA1554 temp123456 Chip Amps 7 6th December 2010 10:19 AM
tda1554 amp attempt... mikee12345 Chip Amps 20 27th January 2010 05:27 PM
Where can i get a TDA1554 Ridin '24'z Vendor's Bazaar 1 20th February 2007 04:43 PM
little or no amplification on tda1554 kasemodz Chip Amps 10 26th May 2006 03:37 PM
