another 3886 build question - diyAudio
Old 27th July 2015, 02:16 PM   #1
Default another 3886 build question
Hi all,
I am thinking about building a 3886 amp to see what all of the fuss is about.
I have been reading through various build threads and my head is spinning.
Would a good place to start be to just buy the PE Yuan Jing 3886 and maybe mod if needed?
Also, would the PE closeout Abletec switch mode power supply work with this? Or does it work better with something else?
Thanks!!!
Old 27th July 2015, 11:09 PM   #2
Do you already have a suitable smps or transformer that you can use?
Get the amp working and then decide what final PSU would be suitable.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th July 2015, 11:56 PM   #3
Thanks Andrew. That makes sense but I don't have any kind of smps or power supply unfortunately.
Old 28th July 2015, 12:18 AM   #4
dab is offline dab  United States
Default batteries are a good option
when I built my first gainclone I had problems with hum/grounding. I ended up trying batteries and was happy. I series connected several batteries and used two capacitors 1000uf and two resisters 4.7k in voltage dividing network. the network gave me a positive, negative and ground.
G Luck dwayne
PS I was a total nooby then, Now I only feel that way most of the time
make hifi not bombs
Old 28th July 2015, 01:05 AM   #5
you can purchase 4 piece of 9v dry cells.
http://www.klu.com/images/articles/a...7470240e_5.jpg
like thisone.
it is easy to chain them up to get a pretty nice 18-0-18 dc test supply.
V*A=VA
V*A*PowerFactor = WATT
Old 28th July 2015, 08:03 AM   #6
like thisone.
I always use 9v batteries for testing if I can get away with it. You're less likely to burn something up than if you hooked it up to a power supply.
You should have an idea how fast the batteries should drop for your circuit; if you watch the voltage drop, you can get a clue if something's amiss without burning up expen$sive parts. Just two days ago I was performing preliminary DC checks on a new construction when I noticed that the voltage was dropping fast. The DC voltages were close. I thought the circuit was oscillating, but I had merely forgotten to short the input for the test. I figured this out with a VOM that you could buy at Menards. The circuit works great and I'm working on the input board and fitting everything into the small case.
Old 28th July 2015, 08:03 AM   #7
Philfr is offline Philfr  France
Hi all,
I build this amp powered by Li Ion :
LM1875 P2P "solar powered"
Batteries came from a drill and give about 15 volt..
I have used with LM3886 (just for a test) and it's works well too.
I always found that amps powered by bat sound better.
Maybe you have cordless drills..
Phil.
Old 28th July 2015, 05:04 PM   #8
aye, i like battery powered amps too.
pre-amps i have all use rechargeable batteries with a floating charger connected when they are not in use. a simple relay solves the automatic charging problem.
less noise i have thisway.
V*A=VA
Old 29th July 2015, 01:56 AM   #9
The LM3886 amps are very sensitive to passive components. A Chinese amp with cheapo parts is probably not the best way to exploit what this chip has to offer. If built with good parts, there really is no need for a tube preamp to get smooth, spacious sound. I would be wary of one of questionable quality. You get what you pay for. Depends on what you intend to do with it.
There are plenty of 3886 kits available to build from scratch, using good parts instead of hacking away at a cheap PCB that will probably lose pads with the touch of an iron. Look closely at the MyRef series, an excellent design which goes a step further and is a bit more complex but pays huge sonic rewards. There are boards available right now in the Swap Meet, and documentation here is excellent.
Peace,
Tom E
Old 29th July 2015, 07:35 AM   #10
tomchr is offline tomchr  Canada
tomchr's Avatar
Many hum problems can be combatted by using a differential input. I suggest looking at the Jensen JT-11 transformers or the THAT1200 IC. Not only do the transformers/ICs get rid of the obvious hum, they also get rid of the hum-induced IMD or "fuzz" in the sound.
Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
3886 Ebay kit Build fabricated Chip Amps 230 21st February 2016 03:39 PM
6n11 + 3886 build questions revel8or Chip Amps 22 13th September 2014 06:35 AM
Chipamp 3886 Mono Beta Build JL889 Chipamp 4 21st November 2011 02:31 AM
First 3886 Build (multiple questions) lost eden Chip Amps 19 13th November 2011 01:25 AM
chip amp build for tower speakers... LM1875 vs 3886... wankski Chip Amps 9 28th October 2010 05:53 AM
Copyright 1999-2017 diyAudio
