Lm3886 bridged - diyAudio
Old 24th July 2015, 06:03 PM   #1
jjrh88 is offline jjrh88  Canada
Default Lm3886 bridged
So what's the deal with a bridged/parallel lm3886?
I saw this DIY BPA300 6x LM3886 300W audio Amplifier and didn't realize the lm3886 could even be run this way. I couldn't find mention in the TI datasheet.
I thought doing bridged was what the lm4780 ( LM4780 | Mid/High-Power Class D Amplifiers | Audio | Description & parametrics ) was for.
I also noticed there is not a whole lot of information on the lm4780 - is there something that dissuades folks?
Old 24th July 2015, 08:38 PM   #2
National have detailed application note for the BA100, PA100 and BPA200. The last can be extended to BPA300 if you use enough chips.
Me, being skeptical of National's intention, has previously suggested they came up with this just to sell more chips. But they did partially sort this by offering the LME498xx series of driver chips which in my blinkered opinion are a far better solution.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th July 2015, 07:31 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
The LM3886 is not really well suited for bridging due to its output current limit. Two LM3886es in parallel can be bridged with another two LM3886es in parallel (BPA200). However, you'll likely find that the matching in offset voltage is much better between two channels of an LM4780 than between two LM3886es. Hence, I chose the LM4780 for the Parallel-86. You have less fighting between channels that way. You can bridge two Parallel-86 circuits and get over 300 W out.
The LM498xx chips are nice indeed, though a tad more involved than the LM4780/LM3886 if you want good performance. Tradeoffs, tradeoffs...
Tom
Modulus-86: Composite amp achieving 0.000067 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com - Engineering : : Done : : Right
Old 29th July 2015, 02:45 PM   #4
Originally Posted by tomchr View Post
.............You can bridge two Parallel-86 circuits and get over 300 W out...............
To get 300W from a bridged pair of amplifiers, each amplifier in the bridged set up must give out 150W into half the final load impedance.
i.e. two 150W into 2ohms amplifiers give a 300W into 4ohms amplifier when bridged.
or two 150W into 4ohms amplifiers give a 300W into 8ohms amplifier when bridged.
How many parallel-86 amplifiers are required to get one channel of 300W when bridged?
regards Andrew T.
Old 29th July 2015, 04:49 PM   #5
Default bridge/parallel + gain mods
Here's a fun question:
What is the difference between:
a bridged pair of LM3886 with a gain of ~14dB each (5V/V),
vs.
a paralleled pair of LM3886 with a gain of ~26dB each (20V/V)?
(hopefully my gain math is right)...
The final amp's overall gain should be the same, right? And the total load "seen" by each chip is also basically the same? Of course, the paralleled pair would have the typical DC offset/amps fighting each other challenge, but besides that, what would be the differences and pros/cons of either approach?
Old 29th July 2015, 05:14 PM   #6
assume the individual amplifiers are rated for a 4ohms load.
The individual amp is 50W into 4ohms.
The bridged pair will be a 100W into 8ohms amplifier and the output voltage will be ampgain*2*input voltage.
The parallel pair will be ~90W into 2ohms, or 52W into 4ohms and the output voltage before the load sharing resistors will be amp gain*input voltage. The available voltage power at the "external" load will be 1dB to 0.3dB less.
regards Andrew T.
Old 30th July 2015, 12:21 AM   #7
tomchr's Avatar
Two Parallel-86 boards, bridged, should be capable of providing approx. 320 W into 4 Ω from a 28 V supply. My math is a tad optimistic in that it does not account for the increase in dropout voltage of the LM3886 as the output current increases. Perhaps I should change my verbiage from "over 300 W" to "near 300 W" or "about 250 W".
It's true that each half of the bridged amp would drive half the load impedance. I have run the Parallel-86 at 2 Ω load without issues. It provides low THD and good performance up to about 125-130 W on a 28 V supply. Following your math, this would imply 260 W into 4 Ω when bridged. So I was off by 0.6 dB. My bad...
I can certainly see good use cases for the Modulus-86 and Parallel-86 circuits. They compliment each other well. The Parallel-bridge is really pushing the envelope. Compared to an LME498xx design, the main advantage is that in the Parallel-bridge, there's no bias adjustment to worry about. It's a bit more plug-n-play.
Tom
Old 30th July 2015, 09:56 AM   #8
................. I have run the Parallel-86 at 2 Ω load without issues. It provides low THD and good performance up to about 125-130 W on a 28 V supply.................
I thought you were claiming good performance of around 35W to 50W from a single 3886.
The parallel should get to around double this, i.e. around 70W to 100W, less a small amount for sharing resistor losses.
What has changed in the parallel-86 that allows 125W to 130W?
regards Andrew T.
Old 30th July 2015, 10:49 AM   #9
Mod-86 is happy up to the full rated 68W, just 50W is a nice sweetspot of easy thermals.
Old 30th July 2015, 11:29 AM   #10
That was not what Tom stated way back.
He showed much data, upon which he relies, to indicate that 35W was the maximum output and to show that high voltage supply rails were unsuitable.
regards Andrew T.
My Bridged LM3886 robertj88 Chip Amps 12 31st October 2010 04:47 PM
Lm3886 Bridged Problem kanifee Chip Amps 14 8th September 2008 11:03 AM
Bridged LM3886 (again ?) Puffin Chip Amps 24 14th February 2008 09:10 AM
LM1876 bridged or LM3886?? aniruddha Chip Amps 5 25th October 2007 07:33 AM
Looking for a PCB for bridged LM3886 zafira1981 Chip Amps 1 29th March 2006 04:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
