| Chip Amps Amplifiers based on integrated circuits |
#11 |
#12 |
How would you rate the X-phono. They go reasonably cheap on Ebay.
Shoog |
#13 |
It's the only phono stage I've heard, and it sounds pretty good to me. Solid as a brick too.
#14 |
Location: Lessons In Electric Circuits -- Volume IIjjjjjjjjjjLessons gn Electric Circuits -- Volume IILessons In Electric Circuits -- Volume IILessons In Electric Circuits -- Volume IIjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
Ropie:
exellent amplifier one of best looking case, I had not seen any like it before, what is schematic? - congrattulatons on your work! Esra
Lesson |
#15 |
Thanks Esra,
The schematic is taken from Decibel Dungeon, which is adapted from the one originally put forward by Joe Rasmussen on Tube Gainclone for DIY, another great website! |
#16 |
Where did you got idea for case?
I woud like build hybrid amplifier , have meny years with valve amp but also too expensive to buy, only built for others. Do you know how is performence when compare to SE amp or any other gain clon?
Lesson |
#17 |
The case is made from wood as I find it much easier to work with than metal. It is designed to have as small a footprint as possible (with no particular height restriction) and to be fairly efficient at keeping itself cool. The vents also allow glimpses of the valves. I'm not familiar with SE amps (?) but the VBIGC sounds much richer and more velvety than my original non-buffered IGC. Have a look at the sites I mentioned before. |
#18 |
I like inspiration for case for new amplifer, probably make from wood as cheaper and more nice to look than metal. I like to ask you to make but peru is very very far from UK
Do you or anyone have other example of amp with very good case? I have seen some but not any so good....
Lesson |
#19 | |
HERE ?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#20 |
Exellent Nuuk! I very much like you GC mono blok!
Lesson |
| Another VBIGC :) | Kermit | Chip Amps | 15 | 26th June 2006 08:05 PM |
| VBIGC T-net with active x-over ? | Will | Chip Amps | 1 | 16th June 2005 09:51 AM |
| An other VBIGC question | ebijma | Chip Amps | 2 | 3rd April 2004 09:19 PM |
| what does the 1n3 cap in JLTi VBIGC do? | sandro600 | Chip Amps | 2 | 5th March 2004 07:40 AM |
| VBIGC troubles... | sith | Chip Amps | 17 | 21st January 2004 09:50 AM |
| Page generated in 0.11697 seconds (75.43% PHP - 24.57% MySQL) with 11 queries |
