Question: Single Point Grounding - diyAudio
Old 8th July 2015, 04:40 AM   #1
Default Question: Single Point Grounding
Hello, I'm new to this forum so I'm sorry if this is the wrong place for my question.
I'm building a simple headphone amp/mixer that will mix a guitar signal with a stereo aux in and send both out to headphones. I'm using a 9V battery for my prototypes, but eventually I want it to share the 9V wall-wart that my effects pedals use.
I'd also like to use a TRS jack with the power ground connected through the ring, so that the 1/4" mono guitar input acts as a power switch. That way, I can leave this device permanently on my pedal board, but this device would not use power if I'm not using it.
I've read some about having the grounds connect to the chassis at a single point to minimize noise, so I'm planning on only grounding the PCB circuit to a volume pot and into the chassis. All of the I/O jacks' grounding will just be to the chassis and not directly connected to the PCB. Also the circuit is all analog.
Would there be any problems with this method? Please let me know if you need more details about my circuit.
Thanks!
Old 8th July 2015, 07:05 AM   #2
Did it Himself
richie00boy's Avatar
Your PCB ground to chassis connection is relying on the pot body. I think you are better off putting a wire from the PCB to a tag on the chassis, and forget grounding the pot with that link.
Try it, you might have some hum or noise issues. If you do then you can use isolated sockets for i/o and ground them at the PCB.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 11th July 2015, 09:28 AM   #3
I don't understand the 9V DC
It looks to me that the Guitar signal is returned from the R of TRS through the 9V and then comes back to the PCB.
The T & R may be a balanced signal (S is correctly connected to Chassis) and need to be processed as a balanced impedance signal.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th July 2015, 02:50 PM   #4
Michael Bean's Avatar
That's just the standard method to switch power in effects pedals on and off. It works by using a standard 1/4" TS "mono" plug to short the ring to the sleeve in a TRS jack, thereby connecting the battery to ground. It's normally the output jack on the pedal and is usually labeled "Out/Power."
Mike
Old 12th July 2015, 06:34 AM   #5
Mike
Yes sorry if that wasn't clear. Only the jack is TRS, but the signal in is unbalanced an will use a TS plug.
Is the connection of the pot body to the chassis not reliable? Would using one of the jack sleeves (say the headphone jack) to the PCB ground be better? I haven't gotten all of my hardware yet, but I don't think the chassis will have lugs in it, so I guess I could mount one myself if it's necessary.
SynTripP: 2-way 2-part Virtual Single Point Source Horn weltersys Multi-Way 93 13th August 2015 03:30 PM
Single Point Stereo Speakers OffGridKindaGuy Multi-Way 14 20th August 2014 02:01 AM
Simple SE Point to Point grounding force of 1/2 Tubelab 3 30th December 2013 09:56 PM
single supply AC grounding question .... Minion Power Supplies 2 28th February 2012 10:06 PM
Single ended transformer grounding question Captn Dave Tubes / Valves 1 29th January 2009 05:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ę1999-2015 diyAudio
