TDA2009A Hi-Fi audio amplifier not producing output - diyAudio
Old 28th June 2015, 03:26 PM   #1
Default TDA2009A Hi-Fi audio amplifier not producing output
Dear Members,
I built a new TDA2009A Hi-Fi audio amplifier for 5.1 surround system. I prepared three TDA2009A PCB boards for driving 6 speakers. Each board is supplied by individual power supply made of 30V step-down transformer, KBP206G bridge rectifier, 2nos. of 2200MicroF capacitors in parallel, L7824CT 24V positive voltage regulator. And also attaching schematic diagram for your reference and this is different from PCB layout shown in TDA2009A datasheet. Now the problem is that sometimes i am getting output from single channel and most of the time I am not getting output from amplifier boards. Please look into the schematic and provide your suggestions and i spent lot of time to debug the circuit but in vain not able to get the sound from amplifier boards.
Thanks.
Bhaskar
Dear Members,
I built a new TDA2009A Hi-Fi audio amplifier for 5.1 surround system. I prepared three TDA2009A PCB boards for driving 6 speakers. Each board is supplied by individual power supply made of 30V step-down transformer, KBP206G bridge rectifier, 2nos. of 2200MicroF capacitors in parallel, L7824CT 24V positive voltage regulator. And also attaching schematic diagram for your reference and this is different from PCB layout shown in TDA2009A datasheet. Now the problem is that sometimes i am getting output from single channel and most of the time I am not getting output from amplifier boards. Please look into the schematic and provide your suggestions and i spent lot of time to debug the circuit but in vain not able to get the sound from amplifier boards. Also note that complete circuit is made by me due to this circuit is not functioning properly.
Thanks.
Bhaskar
Dear Members,
Thanks.
Bhaskar
Dear Members,
Dear Members,
Thanks.
Bhaskar
Dear Members,
Thanks.
Bhaskar
Dear Members,
Thanks.
Bhaskar
Dear Members,
Thanks.
Bhaskar
Old 29th June 2015, 02:22 AM   #2
johnr66 is offline johnr66  United States
Download the datasheet for the IC and look at the application circuit. The chip will not function properly if you don't follow the manufacturers suggested circuit. For one thing, you left the inverting inputs open (pins 2 and 4).
Lay the board out so the external components are close to the chip as possible and the return grounds for the input and negative feedback don't have power currents flowing in them (research star grounding).
Finally, build one prototype circuit and test for proper operation before building the entire amp.
AV400v2 - Another 400W Hi-Fi audio amplifier with remarkable sound donpetru Vendor's Bazaar 16 30th March 2015 09:54 AM
fli amp not producing audio rrae Car Audio 13 15th May 2012 08:04 AM
Easy to do audio Hi Fi amplifier P16W2R mac1257 Solid State 4 21st September 2011 09:09 AM
100W Hi-Fi audio amplifier! radio Solid State 50 17th September 2011 07:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
