LM 3886 kit recomendation - diyAudio
Old 26th June 2015, 05:07 PM   #1
pguerin is offline pguerin  France
Default LM 3886 kit recomendation
Hello everybody,
Wich lm3886 stereo kit or bare PCB can you recommend ?
Modulus 86 boards seems interresting, but too expensive IMHO.
Old 26th June 2015, 06:11 PM   #2
Philfr is offline Philfr  France
Hi P....,
Modulus 86 is a very good way, maybe the best way for LM..
Cheaper, kit from Chipamp.com :
LM3886 "fullrange"
What is your speakers today ?
Phil.
Old 26th June 2015, 06:48 PM   #3
Having built one of the X-Y ebay kits, I can say that they do indeed function, and I'm pretty happy with the sound. There are probably 1000's of posts on the board about this.
In hind sight, I think I would have rather gone for the chipamp.com kit mentioned above as after all my readings, I think the PS board is better.
YMMV as they say on the boards.
Dave
Old 27th June 2015, 05:50 AM   #4
Hi Phil,
My speakers are still the Nomex 164 from TG.
I'm planning to build the Elsinore from Joe Rasmussen this summer, a kind of upgrade
Best regards,
Pascal
Old 27th June 2015, 06:54 AM   #5
Hi Pascal,
LM3886 "fullrange" will be fine with the Elsinore, it can get about 55 watts..
Total cost is between 200/300 euros, depends of quality of case, connectors and so.
Two guys built this amp with sucess, and I can help you to find components.
Regards.
Phil.
Old 27th June 2015, 07:38 AM   #6
John C is offline John C  United Kingdom
John C's Avatar
Hi Pascal,
If you are going to build Joe's speakers..... then his "current" amplifier would be the logical or even the only choice....
I have a First Watt F1J current amp and it's just amazing.... my speakers are REF3A Episode and it works superbly with them. I will not change my amp....ever...
regards
L8TER... JC
Old 27th June 2015, 07:45 AM   #7
John C's Avatar
Here....
Joe Rasmussen "Trans-Amp" - 40 Watt Transconductance "Current Amplifier"
L8TER... JC
Old 27th June 2015, 11:15 AM   #8
I don't knaw nothing about Joe Rasmussen "Trans-Amp", but it use LM3875, basically 3875 don't works with 4 Ohm load, except with very low power and low distorsion..
What power with Trans-Amp in 4 ohm load ?
Phil.
Old 27th June 2015, 12:18 PM   #9
I also own a linear 2X38v PSU And an 1U case, I'm thinking of buying two Hypex UCD 180 HG amp module has an alternative. Any advice ?
LM 3886 Hum bluemike Chip Amps 7 30th October 2014 07:42 PM
Lm 1875? 3886? aquapiranha Chip Amps 12 14th September 2009 08:30 AM
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
LM 3886 Tips... -_nando-_ Chip Amps 39 10th January 2006 06:27 PM
LM 3886 stereo kit for the UK pete.a Chip Amps 3 16th August 2005 02:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
